bad ecm or what
Old Dec 11, 2002 | 11:42 PM
vettered85's Avatar
vettered85
7th Gear
Default bad ecm or what
i can not get any codes pulled from my ecm , when i ground a and b terminal i get overdrive light on, how do you check if ecm is bad, car is not running currently, low fuel pressure well change pressure regulator when have time as suggested by a forum helper
Old Dec 12, 2002 | 02:26 AM
drive it's Avatar
drive it
Default Re: bad ecm or what (vettered85)
Not even a 12?
Old Dec 12, 2002 | 04:29 PM
ZylaRace's Avatar
ZylaRace
Default Re: bad ecm or what (drive it)
When jumping A->B, all the relay's should energize,...... you should hear plenty of clicks, as well as the fan, and fuel pump power up. Check Engien light should come on.
We are talking about an 85, w/ 870 EMC, right?
I'd suspect wiring, fuses,....
Old Dec 12, 2002 | 05:53 PM
Bluevette85's Avatar
Bluevette85
Is the check engine bulb burnt-out? It should light when the key is turned on but not started.
Old Dec 13, 2002 | 08:33 AM
Goody's Avatar
Goody
Default Re: bad ecm or what (Bluevette85)
How's the battery holding up?
That battery light should be on when the key is in the on position as well without the car running.
Hate to ask, but are you sure you did the currect pins?
To bad ecm or what
