H codes
Old Mar 22, 2021 | 07:29 PM
Twoney_money's Avatar
Twoney_money
Cruising
Default H codes
I understand that h codes mean they were a problem, but are currently not one right now. My car is throwing an H48 in module 4, H72 in module 9, and an H24 in module A. I just got the service manual today, but I see two things for DTC 24 which are for the courtesy lamp but also the vehicle speed sensor and am a little confused. Additionally, I am curious because they are all h codes, do h codes trigger a check engine light? I am looking at the H48 and H72 codes in the service manual and am curious about how to decipher between modules 1,4,9, and A. Any help is greatly appreciated.
My car- 1994 c4 corvette base model coupe with a 6-speed manual. The only thing I have done is replace the EGR solenoid to fix a check engine light prior, I installed led lights in the car (maybe why it is an h24, but they are no polarity so should be good
Lights Lights
) and then I installed a new ignition cylinder because the old one was broken, replaced the fuel pump, and the rest were all irrelevant.
Old Mar 22, 2021 | 08:16 PM
Kevova's Avatar
Kevova
H means history and not present fault falls under intermittent
C means current so fault it present and should be able to accurately diagnosed.
Some codes will only set or be current with engine running.
Old Mar 22, 2021 | 08:24 PM
Twoney_money
Cruising
can i put the car in diagnostic mode while it is running? when i turn the car on the check engine light turns on.
Old Mar 22, 2021 | 09:04 PM
Kevova's Avatar
Kevova
You can, you won't get codes. You will.need OBD1 capable scanner with correct programming.
Old Mar 22, 2021 | 09:20 PM
Twoney_money
Cruising
the air bags were removed on the vehicle before i bought it, but i wired a resister to the clock spring to remove the air bag light.
I open the diagnostic mode, review codes, clear codes, take out paper clip, start the car, check engine light comes back on, those h codes come back on when i go back into diagnostic mode.
Old Mar 22, 2021 | 09:21 PM
Nomake Wan's Avatar
Nomake Wan
For a 1994, if you have a laptop, your best bet to do current codes and datalogging is this cable: http://aldlcable.com/products/aldlobd2u.asp
And this free software: http://fbodytech.com/eehack-2/download-eehack/
As to your codes, here is what they mean:
Module 4 (Engine/Transmission) H48: MAF Sensor Circuit Error (car switches to Speed Density mode when this DTC is set; should not significantly impact operation)
Module 9 (ABS/ASR) H72: Serial Data Fail (this can be ignored; it’s likely a result of your diagnostic efforts and is not a real problem, feel free to reset it)
Module A (Airbag) H24: Initiator Circuit Voltage Low
If you do not have a Factory Service Manual, buy one. They are about $30 on RockAuto (look at the bottom of the “literature” section).
Old Mar 22, 2021 | 09:26 PM
Twoney_money
Cruising
Would this work instead: https://www.ebay.com/itm/13320491757...BoC1c4QAvD_BwE
Old Mar 22, 2021 | 09:31 PM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by Twoney_money
No. Your car is not OBD2, it is 8192 ALDL. The cable I linked is what you need.
Old Mar 22, 2021 | 09:33 PM
Twoney_money
Cruising
Ok, thank you for pointing that out. would have bought the wrong one
Old Mar 22, 2021 | 09:35 PM
Twoney_money
Cruising
There are airbags in the passenger seat, just not the driver seat because the steering wheel is an aftermarket one. And the car runs perfectly fine, it is just shooting codes that I think are not a part of the engine itself.
Nomake Wan's Avatar
Nomake Wan
Originally Posted by ihatebarkingdogs
You have to clear the codes in each module when the 'paperclip' is shorting the CCM diagnostic enable port to ground. (I don't know the pin numbers for the 95's port. Don't care to look them up). If you have codes in 3 modules, you have to clear in 4.9, 9.9, and A.9.
If you don't have airbags, why not remove (or just disconnect) the DERM and jumper the correct 2 cavities in the connector so the engine still runs? (I'm not going to tell which 2 it is. Liability chit....).
Clearing codes is #.7, not #.9.
OP already knows which pins since he already knows how to enter diagnostic mode, but for reference it is 4 and 12.
Old Mar 23, 2021 | 07:58 AM
WVZR-1's Avatar
WVZR-1
i edited the post a-hole. In your HASTE to copy my post, nowYOU HAVE MADE AN ERROR. Please extend the courtesy of fixing your post pointing out the error that i corrected within about 2 minutes. Look at the difference between the post time and the edit time.
Q U I T C O P Y I N G M Y P O S T S.
This is pretty damn 'entertaining'
OP for a late C4 @Nomake Wan is pretty damn reliable and responsive. A week ago I actually believe I suggested a 'house-call'. since you/he are 'left coast' neighbors. You've got the FSM now so spend some time acquainting yourself with it.
Is your FSM paper or .pdf?
To H codes
