Looking to add chip
Old Mar 27, 2021 | 05:09 PM
PikeBoy's Avatar
PikeBoy
Navigator
Default Looking to add chip
Just picked up a 92 with automatic. Can anyone recommend a chip I can use? The car is stock base. I see Hypertech and Jet a lot.
Old Mar 27, 2021 | 06:40 PM
Nomake Wan's Avatar
Nomake Wan
Hypertech is absolute crap. JET is probably just as crap. The only "chip" worth putting in is one you do yourself because all the cars are different and a dyno is how you do it properly. On a stock car a chip isn't going to do you any magic.
Ostrich is how to do real-time tuning on a '92, and you'll need a Moates G1 Memory Adapter to be able to plug chips and the Ostrich into the ECM. Good luck.
Old Mar 27, 2021 | 07:16 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Was wondering what you want the chip to accomplish?
Reason for asking is that with an automatic your best bang-for-the-buck is often just a change to the gear ratio in the rear-end.
Do you know what the gear ratio is in your rear diff currently?
Old Mar 27, 2021 | 07:30 PM
vader86's Avatar
vader86
Junk. Do not waste money here.
Spend your money on real changes, headers, exhaust, 1.6RR.
Old Mar 28, 2021 | 12:07 PM
aklim's Avatar
aklim
Those are cheap and easy items. Doesn't do more besides lightening your wallet and makes you think you did good. I'm told the placebo effect is decent. I would change all fluids and make sure everything is on top before buying those "up to X HP" things. We could dyno tune the car but for what you get, the ROI is going to be so low, you are going to kick yourself in the *** once you get more familiar with it. Make some changes like say fluffing intake and heads, headers and cam then get it dyno tuned to dial it in.
Old Mar 28, 2021 | 02:13 PM
93TALT4A4's Avatar
93TALT4A4
Pcmforless and other tuner "Chips" can help you pick up a couple tenths and a couple MPG, at least on stock 93 Fbodies. The factory tune for the LT1 (Y, F, or B-body) is pig rich. Gains to be had even on a stock car. Being speed density you'll have to order the tune and an adapter. But tunes are always worth it.
Old Mar 28, 2021 | 02:52 PM
aklim's Avatar
aklim
Is that a lot? I heard that is is possible on the F-body or B-Body but I recall, and it might be wrong, that the Y-body is pretty optimized and the gains are minimal on stock mode anyway,
Old Mar 28, 2021 | 03:07 PM
PikeBoy's Avatar
PikeBoy
Navigator
Like other GMs I've owned, this trans wants to get into lockup asap. This is the first auto Corvette I've owned and thought a chip would help in changing the shift points and lockup. The car runs strong for my needs but this bothers me.
Old Mar 28, 2021 | 03:11 PM
aklim's Avatar
aklim
Can you? I thought they are not adjustable from the ECM? https://www.corvetteforum.com/forums...92-lt-1-a.html
Old Mar 28, 2021 | 05:38 PM
PikeBoy's Avatar
PikeBoy
Navigator
Thanks for that link aklim. That is everything I need.
Old Mar 29, 2021 | 12:40 AM
Nomake Wan's Avatar
Nomake Wan
A tune that's done with actual data can be worth it...ish. You're still not going to see any gains that'll make the cost of the tune worth it on a totally stock car. If you make some decent changes mechanically, then absolutely it'll be worth it. But an off-the-shelf chip like a JET or Hypertech or whatever else isn't worth the chip it's burned on, especially on a '92 that doesn't have transmission control like a 94-96 would.
I'm all for tuning. I'm just not for magical chips that make silly claims for stock cars.
Old Mar 30, 2021 | 11:01 PM
93TALT4A4's Avatar
93TALT4A4
$400 for .2 / 20hp / +2mpg is worth it..ish?
Relative I suppose....
Catbacks offer no power no mpg, only tone? How much does a Corsa cost?
How much gain do headers give? Read LT1s make 10-15 with long tubes. Shorties aren't worth 5-7. How much do those cost? Heard installs are fun. So are tracing exhaust leaks and burnt wires. A tune is plug and play...5 minutes.
Just saying...
Old Mar 30, 2021 | 11:41 PM
aklim's Avatar
aklim
Just saying...
I agree. With a race car, for instance, it is a bargain. For a stock car, I really don't see it.
My latest one said it is about $1500 but it quietens down the engine a lot, no drone. I had Borla Stingers and were they loud. I reinstalled a functioning cat just to make it drivable. A run to the grocery store is all it was good for otherwise. Drive for an hour and the noise beats you up. Now it is way better. Glad it got loose and hooked on something and ripped stuff off. Insurance covered it so I added some more and got a Corsa. Otherwise I wouldn't be able to justify $1500 for a car I didn't plan to keep forever.
Aren't the stock manifolds almost equivalent to shorties by themselves? For the headers to be worth it, maybe more should be done and a dyno tune or at least one where the guy datalogs and gets things dialed in? I don't know if anyone is good enough to get it all spot on. Maybe the WOT but the drivability might suffer if you guess a tune off the specs.
Old Mar 31, 2021 | 01:18 AM
Nomake Wan's Avatar
Nomake Wan
Just saying...
Catbacks can be made custom for a fraction of the cost of a Corsa if all you want is the power increase of going to a wider exhaust system. Even an off the shelf Magnaflow is a fraction of the cost of a Corsa. The cost of the Corsa is in its production. Similar to $10k+ exhausts for shitboxes that make them sound "racy" but do zilch for performance and are there for the status symbol. Super dumb, but if that's what you want, you're paying for the labor and the nameplate.
A tune is not "plug and play 5 minutes" unless it's an off-the-shelf chip, and if it's an off-the-shelf chip it's crap. A real tune requires actual datalogging and trial-and-error work. And on a stock car, it's really not going to net you very much. It's just not worth the time or the money unless you have the equipment to do it yourself. I've got everything but the dyno so it's not an issue for me, but for OP it probably would be.
So hey, if you think it's worth it, more power to you. I just don't see the point on a stock car. There just isn't as much headroom as you think there is, and what headroom there may be doesn't justify the time and money a real tune would cost (that you'd have to spend again if and when you actually make mechanical changes down the road).
Old Mar 31, 2021 | 01:23 PM
93TALT4A4's Avatar
93TALT4A4
Originally Posted by Nomake Wan
A tune is not "plug and play 5 minutes" unless it's an off-the-shelf chip, and if it's an off-the-shelf chip it's crap. A real tune requires actual datalogging and trial-and-error work. And on a stock car, it's really not going to net you very much. It's just not worth the time or the money unless you have the equipment to do it yourself. I've got everything but the dyno so it's not an issue for me. So hey, if you think it's worth it, more power to you. I just don't see the point on a stock car.
I didn't know you were a were a tuner like Mad Tuner, Brian at PcMforless, and Ed Wright. Odd, those 3 companies and their customer base express the opposite of everything you say. You seem to know more than those guys so i'll take what they all say with a grain of salt. Tell me more about your car. I bet its really fast to give out invaluable advice like mail order tunes are crap.
Old Mar 31, 2021 | 02:27 PM
Nomake Wan's Avatar
Nomake Wan
Please read what I said again--I did not say mail order tunes are crap. I said off-the-shelf chips are crap. If you buy a JET or a Hypertech, it will be crap. It won't be worth the chip it's burned onto. I've said that multiple times, and I'm sure all of those people you named would agree with that sentiment.
Mail-order tunes are just fine--but generally they're ones where you go back and forth with the person while logging data from your car to make sure that it accounts for whatever variance there is in your specific setup. You get a base calibration, log data, send data to the tuner, tuner makes adjustments, repeat until happy. Totally cool. Don't think it's worth it to bother on a stock car, but hey, it's your time and money, do as you please.
My cars are pretty much stock mechanically. One is totally stock, the other just has an intake and an exhaust. Not enough to write home about. Nor would I pretend that "a tune" is going to magically make my car "really fast." I'm not sure what the perceived speed of my cars has to do with knowing what I'm talking about regarding messing about with the ECM/PCM though...
Old Mar 31, 2021 | 02:35 PM
aklim's Avatar
aklim
But do they do that? Datalog back and forth or do they send a tune to the customer, he installs it and they think it is done? IOW, does the tuner send you a tune with the stuff to datalog, make revisions or just rely on your butt dyno to say it is a good match?
To Looking to add chip
Old Mar 31, 2021 | 09:25 PM
Nomake Wan's Avatar
Nomake Wan
The mail-order tuning places I'm familiar with either tell you what you need to log data (on newer cars this is usually just the exact same cable you'd use to flash the tune) or send you a cable, give you the base calibration, have you log data, make minor revisions, send you the new tune, rinse and repeat. I'm sure there are places that'll just send you a "good enough" tune and that's it, and if that's "good enough" for you, so be it. Again, your money, your time, your car.
Old Mar 31, 2021 | 10:40 PM
aklim's Avatar
aklim
Most of what I hear is "good enough" tunes or very rarely, do I hear of them doing datalogs. Most of what I hear is you send a set of specs, he sends you the program in whatever form and you drive it and say "good enough". For say a Lingenfelter combination and them giving you a program, no problem. They make copies of the engine daily. More than that, I guess it depends on how finicky you are, like you say. Like I said, I hardly hear of people doing datalogs which is why I call them "guess a tune".
Old Apr 1, 2021 | 03:40 AM
93TALT4A4's Avatar
93TALT4A4
aklim, you are on the right track. And they are definitely worth it. Driveability is improved as well. Just feels noticeably gustier all over. Have you done a full tune up/syn oil yet, if not it'll feel much stronger everywhere as well. Post up what you get.
You have ZERO mods on your Corvettes and you are telling other people what is worth it. Thats why I asked what mods you had to your car to be a specialist in what mods are worth what. You have nothing to ad based on experience you don't have. FYI- a chip is correct of him to say. 92 and 93 were the last years memecal CHIPs were used. I'm not sure if you knew that. I'm done mucking up his thread. Peace
