Remote/bump start switch hookup
Old Apr 7, 2021 | 10:08 PM
89onlyZ51's Avatar
89onlyZ51
Default Remote/bump start switch hookup
My starter ('88-'91 denso mini-starter) is completely inaccessible for hooking up a remote starter switch. Between headers and a road race oil pan, there's less than a half inch clearance around the terminals. Can't even get my fingers in there enough to squeeze the alligator clips on a remote start switch, and I worry about a short to ground. Anyone know of an easier/more convenient place to hook up the switch? Can the B+ side can go right on the battery? And, can the S-terminal (purple wire) be picked up at the cold start injector fuse or clutch safety switch? The purple wire is smaller at the CS injector fuse but is full-sized all the way to the clutch safety switch. I happen to have decent access to that connector right now.
File Type: pdf
Old Apr 7, 2021 | 10:24 PM
89onlyZ51's Avatar
89onlyZ51
Answered my own question - hooking the start switch to + on the battery and the purple wire on the clutch safety switch works like a champ. Sure beats crawling around under the car!
Old Apr 8, 2021 | 10:12 AM
JoBy's Avatar
JoBy
I put a small 4 mm "banana jack" near the brake booster.
Old Apr 8, 2021 | 11:08 AM
89onlyZ51's Avatar
89onlyZ51
What did you wire it to?
Old Apr 8, 2021 | 11:47 AM
JoBy's Avatar
JoBy
Same purple wire after starter interrupt relay. ( Mine is an 1984 )
( I see two risks. If ignition is on it might start and it will crank in gear also. That is the reson that I did not want to install a permanent button. )
To Remote/bump start switch hookup
