Eliminator question
Old Dec 13, 2002 | 08:48 AM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Default Eliminator question
I now have the XR1 Borla Cat Back with Random Tech high flow cats but want to remove the Borla mufflers and put on Eliminators that by the way should be getting here any day . Can this be done or am I going to run into problems getting the Eliminators on ? thanks folks :yesnod:
Old Dec 13, 2002 | 09:15 AM
90qzrblu's Avatar
90qzrblu
Default Re: Eliminator question (DINO)
That would seem to defeat the purpose of buying a Borla system? If you just wanted elims, why dish out the dough for a Borla system? :confused:
Old Dec 13, 2002 | 09:25 AM
DINO's Avatar
DINO
Default Re: Eliminator question (90qzrblu)
I have had the Borla's on for years , and that wasn't the question...I just want a change :p:
Old Dec 13, 2002 | 09:34 AM
No Ordinary 91's Avatar
No Ordinary 91
Shouldn't be any problem doing that unless you don't want the car to be loud, they will pop a little but nothing major :cheers:
Old Dec 13, 2002 | 09:39 AM
DINO's Avatar
DINO
Default Re: Eliminator question (No Ordinary 91)
See now thats an answer I can work with thanks "No Ordinary 91"!!!
Old Dec 13, 2002 | 09:49 AM
chucks88's Avatar
chucks88
Albeit an L98, my Elims were a direct bolt on to my rear Y-pipe
Old Dec 13, 2002 | 11:01 AM
billyhay's Avatar
billyhay
Cruise-In V Veteran
Hey Dino :seeya
My car has elims if you remember what it sounds like. I bought the ones that are the one piece welded design. I then made two cuts on the old system with a sawsall and bolted these things on. I don't know what the Borla system looks like, but if it resembles the stock system you should have no problems. :cheers: After I bolted it all together I took it to a friend so he could weld it together. Now the only way that thing is going anywhere is when I get rid of it for a Corsa system. :yesnod:
Old Dec 13, 2002 | 09:05 PM
RichS's Avatar
RichS
Hey Dino
Only problem might be a size differance. The eleminators are for a stock 2 3/4" pipe. Are the Borlas the factory size pipes or are they 2 1/2 or 3" ? But you can just get a reducing coupling if they are differant.
Old Dec 13, 2002 | 11:42 PM
Gar's Avatar
Gar
My 95 had them on when I bought it. They are the welded deals from Mid America with the twin tips. I thought they sounded awsome but were to loud and buzzy at high speed, but after driving the car for awhile I have changed my mind. They are staying! :cool:
Old Dec 14, 2002 | 12:22 AM
hngacurv's Avatar
hngacurv
Default Re: Eliminator question (Gar)
I cut my mufflers off right in front of them and just welded in a 8" or so piece between my cut and my chrome tips. The only time mine pops is when I'm idling and rev it up to 4500 and just let off it.
[Modified by castivers, 12:23 AM 12/14/2002]
Old Dec 14, 2002 | 08:35 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yo DINO, you should have just called me, I could have answered that.
Before you do anything, let me know, I have a deal for you, it will only cost you lunch.
Old Dec 14, 2002 | 08:52 AM
RichS's Avatar
RichS
Default Re: Eliminator question (Mr Mojo)
Don't fall for that, it will cost you more buying Frank lunch than driving to the plant that makes them :lol: :lol: :lol:
Old Dec 14, 2002 | 12:33 PM
RX7 KLR's Avatar
RX7 KLR
Only problem is loss of power. I went from eliminators to a custom system with a XR1 on my 89'. I gained 4hp and 10lbs of tq at the wheels. I did prefer the sound of the eliminators but I want the power.
[Modified by RX7 KLR, 11:34 AM 12/14/2002]
Old Dec 16, 2002 | 08:44 AM
DINO's Avatar
DINO
Default Re: Eliminator question (RichS)
Hey Dino
Rich my Borla's are actually 2 3/4 ", I guess Chris at ECS will have to figure it out.... :yesnod:
To Eliminator question
