No heat
Old Apr 13, 2021 | 07:44 PM
Beater12's Avatar
Beater12
Default No heat
On my 90 Vert the push button control on the dash switches from defrost to vent to floor just fine but I get no heat even when I set it to the 37 max?
Old Apr 14, 2021 | 01:48 PM
Beater12's Avatar
Beater12
No one?
Old Apr 14, 2021 | 02:09 PM
PacerX's Avatar
PacerX
Originally Posted by Beater12
No one?
I have not diagnosed a no heat problem on a C4... And mines an 85.
But places to start:
1. Is the blend door moving?
2. Are the lines to and from the heater core warming up?
Do you own the factory service manual?
Old Apr 14, 2021 | 03:35 PM
Siveck's Avatar
Siveck
I’ve written a few posts about this. Search under my user name for blend door or cold solder joints on controller. I’ve had 2 89s with this same issue. First check for blend door operation. Remove resistor on blower box and observe door operation. Reheat cold joints on programmer board above gas pedal. Make a diagram of vacuum hoses because not all colors match. More details in prior post but that is the summary.
To No heat
