Tuner cat problem
Old Apr 13, 2021 | 10:53 PM
95C4Sooner7's Avatar
95C4Sooner7
3rd Gear
Default Tuner cat problem
Has anyone else ever had a problem with tuner cat losing connection in the middle of an upload . Any help would be great!
Old Apr 14, 2021 | 12:51 AM
Nomake Wan's Avatar
Nomake Wan
If you have a 1995 C4 as your username suggests, stop using TunerCat to flash or read your PCM. Use Flashhack instead. It's faster, more reliable, and basically better in every way (including handling "noisy" serial buses better).
http://fbodytech.com/flashhack/
Old Apr 14, 2021 | 04:42 AM
VenkmanP's Avatar
VenkmanP
Usually means you have a flaky cable.
Old Apr 14, 2021 | 11:58 AM
Nomake Wan's Avatar
Nomake Wan
Could be. Or the USB port is iffy. Or the vehicle in question has a noisy serial bus for some reason. My '94 is like that.
Old Apr 14, 2021 | 07:10 PM
95C4Sooner7
3rd Gear
what causes a noisy serial bus??
Old Apr 15, 2021 | 02:40 AM
Nomake Wan's Avatar
Nomake Wan
I honestly have no clue. I haven’t tried to track it down. The software I use is resilient enough to work despite it so I haven’t bothered tracking down the actual problem. Just for whatever reason my 94 has it and my 95 does not.
Anyway, as long as you stop using TunerCat software it won’t matter.
To Tuner cat problem
