Throttle sensor
Old Apr 14, 2021 | 08:31 PM
Jez28's Avatar
Jez28
6th Gear
Default Throttle sensor
Hi all,
Total newbie so please forgive if this has been asked before or if it’s s simple fix.
I am looking to change my BBK throttle body for a new BBK body, when I change the TPS over will it be a straight forward remove from the old body to the new one or will I need to make adjustments?
Old Apr 14, 2021 | 10:56 PM
aklim's Avatar
aklim
Install is easy. 2 bolts or screws. You still have to set the TPS and the min air rate. I'd use a scanner.
Old Apr 15, 2021 | 12:47 PM
Kevova's Avatar
Kevova
Depending on the size of throttle body rubber air intake connector maybe too small to fit over throttle body inlet.
To Throttle sensor
