Oil leak
Looking at it....oil came out around the filter and went into the exhaust. Possibly adapter?
It gets on the exhaust and everywhere.
Pressure spray wash the area clean, go for a short drive and look under the car.
The correct oil cooler seal is available, do not use an old oil filter seal as its slightly too small.
Having said that you can make it work, but need trail and error to get it right with an oil filter seal.
that is just because I am.in OZ a two week shipping wait makes you try these silly things.
Hey it may just be the oil cooler is loose, if the filter had been overtightened it can undo the tube bolt a bit before the filter releases.
So check that as well, remember the seal will be very old now and squashed. So may just need to tighten the tube bolt when oil filter is removed.
Cheers
Gerard
I know we are all speculating. But there are a lot of oil sources in that area more likely than the head gasket.
Cheers
Gerard
And it was burning right off the exhaust on mine.
There are two oil “pressure” related sensors on top of the engine. However, my 1991 L98 also has an Engine Oil “Temperature” sensor located above the oil filter housing. The sensor feeds the instrument panel and, I believe, has no connections to the ECM.
I don’t know if the 80’s models L98s have that sensor. If so, could be his oil leak source.
Edit: After pondering the “fuel sensor” you mentioned, I am sure you were referring to the Oil Pressure Switch that is part of the Fuel Pump circuit. Okay. Got it. The terminology confused my simpleton brain.
