High NO on CA Smog
Old Apr 23, 2021 | 09:41 AM
DennyGriffinJr's Avatar
DennyGriffinJr
Default High NO on CA Smog
1995 LT1 base. Car had 50,000 original miles on it. Aftermarket BBK TB, JET Performance chip, CAT back exhaust.l, K&N filter with the top of the filter compartment cut off. All CARB Compliant stuff with stickers.
NO at idle and load were both about 200 over on NOX emissions. The mechanic had a heck of a time getting the sensor stick both in and out of the muffler..
First question: if that sensor stick is shoved too deep in the exhaust, will it read high NO.
Second question: any way to lower the reading without pulling the intake and cleaning out the NO Exhaust port?
Any and all advice (other than move out of CA), tips, or TRICKS are GREATLY appreciated!!
Old Apr 23, 2021 | 11:07 AM
Nomake Wan's Avatar
Nomake Wan
Curious what a "JET performance chip" is on a '95.
To answer your first question, no. There's no way for the tech to stick the sniffer so far into the exhaust that it'll read wrong. The catalytic converters are all the way up next to the oil pan. There's more than enough distance for the catalyzed exhaust gases to travel.
Best of luck with the smog. Hopefully some folks can help you our with your NOx.
Old Apr 23, 2021 | 11:38 AM
TommyFox's Avatar
TommyFox
There are fuel additives that can help with strict emissions. Sometimes running an MSD box and opening up the spark plug gap can help so I'm told. What do you mean by 'NO port' ?
Old Apr 23, 2021 | 11:43 AM
DennyGriffinJr
This is the Jet PerformPerformance chip/module.
Old Apr 23, 2021 | 12:10 PM
DennyGriffinJr
Someone locally mentioned cleaning the port that the EGR valve is connected to, and that might help lower the NOx on emissions testing.
Old Apr 23, 2021 | 12:34 PM
Nomake Wan's Avatar
Nomake Wan
That's very strange. The '95 PCM uses a flash chip that can be reprogrammed from the ALDL connector under the dash (like modern cars), so I'm not sure what a piggyback would do. In addition the plug on that 'chip/module' don't match anything on the PCM.
Might not be relevant to your issues, but it is curious. I wonder what would happen if you just removed it.
To High NO on CA Smog
