Tuner Driver assist help
U Joints are new, driveline is solid with D44, Ikerds diff, and I cant move any of the half shafts or driveshaft by hand when in the air.
If I drop a gear, to 3rd it all goes away, even when I get in same rpm. Maybe not as pronounced due to speed, but I cant hear it
So, in tuning, what parameters can assist a barely above idle/throttle to keep car from bucking/surging a little.
IAC is failry new, TPS is fairly new. Battery, Alternator new.
Its been doing this for some time, but just now going to tackle it... PCMforless, and 3 other tunes available. None have ever been able to get this surge issue worked, as we couldnt see any symptoms to show it, via TTS datamaster.
Cruise control on?
Is the TPS reading consistently?
The TCC locking and unlocking could definitely cause it, and so could a fluctuating TPS signal, it could be transitioning in and out of DFCO if the TPS signal is noisy.
Not sure if the cruise makes any difference as I never use it at that speed.
TPS is reading fine. I have reset it a few times to ensure its okay, and changed it to anther one. No change.
If the TCC is locking and unlocking, what speed should I change it too? Higher? In OD only?
TCC is lock 47mph low
42mph Unlock low gears
TCC lock high gears 56mph
TCC unlock high gears 42
TCC unlock prevention speed threshold is 64
Also according to calculator if you are using 26' rear tire @ 1800rpm in OD (0.70 ratio) you should be at about 53 Mph hovering right around your Lock up value of 55Mph. Try increasing your Lockup value to 58 or 60.
Tomorrow I will use new lock up speeds.
currently repairing inlaws laptop.
Anyways. I am not sure what tables to compare to on Tuner Cat to see what the differences were in his tune...
But, I will change the lock and unlock and run it Friday, my last day off before traveling off to work outside USA
Here is the VE tables, as you mentioned. The old tune was brought up first, and then I compared by using new tune I just used today..
And here are the two bins files I am working on for the 93 Corvette.
Bin 1 was the file where I had more bucking, surging etc.
Bin 2 is the newest one I used..
