Console and Dash Lighting Out
Old May 7, 2021 | 12:03 PM
monefive's Avatar
monefive
Default Console and Dash Lighting Out
Hey there guys.. I was trying to replace the auto shift indicator light the other day on my 89 with a new pigtail and led bulb. The old bulb was clearly burnt out.. so I thought I would just replace the bulb to start, so I replaced the bulb and tried the lights and nothing, but started to remove it while the parking lights were still on, and it flashed then the dash info switch lights flashed as well, and now everything is out. So, no light from the trans indicator light.. no light from the dash info switch section (the warning lights are all working) and no lights from the stock radio when I switch on the parking lights. The radio is lit up when the parking lights are off, but then goes dark when the lights are switched on.
I was hoping it was a fuse, but all fuses are good. It can't be the bulbs since the radio is being affected as well... any ideas?
Thanks, Matt
Old May 10, 2021 | 08:50 PM
L98boy's Avatar
L98boy
Hey that's horrible. I have no idea what to do, but I am just curious...did you figure it out??
Old May 11, 2021 | 11:51 AM
monefive's Avatar
monefive
No, no idea. I'll have to have the shop take a look when I take it in for suspension work. It was better before I started messing with it.. lol
To Console and Dash Lighting Out
