ZF 6-Speed vs 4L60E - ECU differences?
I picked up a cheap '95 base project car. No crank at the moment. Security light blinks and "press brake" light on. Figured out VATS code and ordered a bypass module - hopefully it's just that. Did alittle more scoping around and I realized this was originally a 6-speed car. The original engine blew. Then PO picked it up and swapped in a used motor. From what I was told he only did the motor swap - nothing with the trans. VATS wires looks like it's been worked on but there is no resistor/bypass in place so I can't really isolate that as the cause for no crank. The pedals have been swapped out..
The bigger problem I'm worried about at the moment is the ECU. Are there programming differences between the ZF and auto cars? Last thing I want to do is start throwing money at this if it's simply ECU/TCU related. Sorry if this sounds odd but I've mainly worked on euro cars and those already require programming for fluid change, let alone a whole MT/AT swap.
It could be a vats issue or park/neutral safety switch. Even if the vats starter solenoid is bypassed, the computer is still looking for the resistance in the key. So unless a resistor has been installed there may be a crank condition where it won't fire off because the computer does not see the key.
If it's not cranking over at all, it may be that they did not properly wire the neutral safety switch to the shifter or it needs adjustment.
USB Cable: http://aldlcable.com/products/aldlobd2u.asp
Flash Software: http://fbodytech.com/flashhack/#Downloads
Factory BIN files: http://fbodytech.com/tutorials/bin-files/
Hopefully the previous owner did the whole swap, including the rear diff. Otherwise the speedo will be way off.
Good luck.
Good luck.
Which one of this BIN files is for the base 95 AT? Seeing a ton of numbers. Is that the ECM code or is there a specific code on the trans?
PO was not very helpful when it came to questions as to what was done and what wasn’t. Looks like he either did the whole swap himself or the guy before him did the trans swap then he did engine only. There’s a low chance that the auto was ever successfully driven in this car. It blew up sometime within the last 11 months from what I see on the Carfax.
Best of luck to you. The one saving grace is the PCM for the 94-95 Corvette is very robust and capable and easy to work with.
This would be sample info very likely for a '95 4L60e & 2.59
1G1YY22P3S5104304 1YY07
AG1 AG2 AK5 AR9 BGR CF7 C68 DL5 DL8 FE1 FE9 GM1 IP3
J55 KG9 LT1 MXO M30 NA5 NK4 QB6 R7A R8T UXO U1F U52
U75 VM3 V73 XAA YAA O5U 1AY 1SB 14I 143
BC/CC WA- U117B 143
GM1 - 2.59
LT1 - engine
MXO/M30 - 4L60e
If in the SPID you find an ML9/MN6 the car was an original ZF
BC/CC WA- U117B 143
GM1 - 2.59
LT1 - engine
MXO/M30 - 4L60e
RPO showing 3.45 rear - assuming it hasn’t been swapped out. PO told me very little about it other than he purchased a new lower mileage motor, resealed it, and bolted it back in. He has no clue if the ECU was touched.
In any event even if the rear diff is wrong this only affects the speedo (and can be fixed later). The code controlling the transmission is what’s important. There are only two variables there—94 or 95. The 4L60E was different between the two. The 95 is going to be a lot more common, so that’s why I suggested it first.
An idiot if they didn’t steal the Dana 44 while they were at it.
@Nomake Wan can maybe better direct you from this point but it would be very important to confirm the components 'present now', each and every one. Are the engine & trans maybe a match from a single car? I'd think very important to know.
Until it's confirmed just what's present is maybe: 'how attached are you to the car'? How many $$$ are invested? In it's current configuration - how saleable is it? Not knowing condition of each component maybe it's an appropriate time to 'ESCAPE'! I doubt it's an inexpensive project. To make run? Might NOT be 'inexpensive' either.
Do you have a shop with access to a lift?
I was able to get under the car. This is starting to look like a headache.
engine code: V0208WTA(vin is not legible on the front of the engine, can’t get to the back)
trans code: 6YDM
rear end: Visually DANA 44
PCM part # 16181333
from what I gather with info off this forum: it is a 1986 700R4 transmission. Considering there’s 2 plugs down in the tunnel with nowhere to plug into, I assume this transmission won’t work.
the rear end looks untouched, and is missing the DANA 36 top bolt. The truss layout also matches that of a DANA 44. So I think it’s safe to assume it’s still original...unless they somehow gutted and ghetto rigged it.
PCM part # is original and according to the PO he “thinks it’s original, untouched”. I get a feeling he picked it up like this and sold the project when he realized the mismatched trans.
Right now I’m trying to figure out my options. I brought this car fully intending it to be a project - but not as half as*ed as this turns out to be. Could I sell it and buy another running driving C4? Sure it means nothing to me. But I have one right now and just want to see if it’s salvageable at this point. It’ll be nice to have it working this summer but it truly is no rush.
assuming the PCM is still tuned for the ZF, and the rear end is still correct, all I theoretically need to do is put in a ZF, clutch pedal, and shifter... it should be turn key. But ZFs look pretty expensive right now. And last thing I want to do is put a few G into a ZF then find out there’s something else missing.
what are my options for an auto? 4L60E and a tune? Possibly a new rear end later on? I seen somewhere that the manual cars don’t have the auto trans harness.
Interior probably 3/10, exterior probably 6/10. Just needs reclear on the outside and new seat covers would make a big difference.
Time to dump it unless you want to restore it with a ZF6.
You've accomplished much in a 'few days'! Now it's time to 'rethink
