trans moves
Old May 8, 2021 | 09:24 AM
santazr1's Avatar
santazr1
Default trans moves
having trouble with manual trans. After putting back together the trans moves up and down on take off and hard shifting. bolts are tight on the c-member what am I missing?? in the past only way to prevent movement is to raise the trans althe wat to the top of the dog house and tighten. i s this right or do I have something else wrong?
thanks
Old May 8, 2021 | 07:35 PM
19corvette91's Avatar
19corvette91
bad motor mounts? batwing mounts?
Old May 8, 2021 | 07:53 PM
SJW's Avatar
SJW
Check those C-beam bolts again. Sure sounds as though that's where the movement is occurring. ZF Doc's C-beam plates might help.
Live well,
SJW
Old May 9, 2021 | 11:01 PM
C409's Avatar
C409
..... Tighten the C-Beam bolts .....
To trans moves
