1992 ecm
Old May 12, 2021 | 09:16 PM
mist979's Avatar
mist979
Default 1992 ecm
I just confirmed today that my ECM is bad. It doesn't appear anyone makes these anymore so looks like rebuild is my best option other than going after market. Not sure if I want to open that can of worms. I found this site that claims to rebuild them ( https://siaelec.com/product/16159278...repair-return/ ). Does anyone have any knowledge or experience with them? Or any advice to my issue?
Old May 12, 2021 | 09:55 PM
GaryInArizona's Avatar
GaryInArizona
Just curious how did you determine your ECM was bad? Thanks.
Gary
Old May 12, 2021 | 10:00 PM
Kevova's Avatar
Kevova
92-93 ECMs have been in c4 parts sub forum. There have been several threads related to 92-93 ECMs you might search them.
Old May 12, 2021 | 11:32 PM
aklim's Avatar
aklim
https://www.autozone.com/engine-mana...searchText=ecm
Old May 13, 2021 | 12:07 AM
Nomake Wan's Avatar
Nomake Wan
SIA Electronics is well-respected in the Corvette community. If your ECM is bad, they are absolutely where you should send it to get repaired.
Old May 13, 2021 | 08:54 AM
mist979's Avatar
mist979
GaryInArizona, I've been working on this car a lot since I bought it in 2016. There are getting to be so many new parts that I think it's going to become fairly reliable soon. Anyway, the most recent problem is it started idling high, then went back to normal, then high idle and it eventually stayed so it idles at 2000 rpms now. So I checked for vacuum leaks = none. So I bought an IAC valve and installed = Problem still exists. I've been suspecting the ECM for other issues such as my AC not working now and all the other components of that system are either new and/or working correctly. So I gave up and brought it to a local shop. Their diagnosis is the ECM isn't sending pulses for the IAC valve. They didn't have a tech1 to try and reset it (Relearn), but I doubt that would be the case anyway. Far more likely a resistor or something burned out in the ECM than it just 'forgetting' the IAC setting.
Old May 13, 2021 | 12:14 PM
aklim's Avatar
aklim
How did you determine there were no air leaks?
I would scan and see if the ecm is responding properly. Set the minimum air rate using IAC counts and tear out the page in the FSM that tells you how to do it without a scanner.
Old May 13, 2021 | 12:27 PM
mist979's Avatar
mist979
I used Propane, then tried brake clean. No vacuum leaks detected that way. I don't know how to scan the ECM to do any of what you're saying. The mechanic told me the ECM wasn't sending pulses to the IAC valve. I don't have an SES light. Either burned out or as indicated in service manual, might be bad ECM. There are some tests I can do for that. Also my AC system won't work and the ECM is the last piece of that system that hasn't been replaced or fixed. It doesn't send current to the relay. If I had more resources and/or knowledge I'd test more thoroughly but evidence so far points to ECM.
Old May 13, 2021 | 12:30 PM
aklim's Avatar
aklim
I would get a scanner so I am not throwing parts at it. 1320 electronics makes a decent one for the android phone. You will need one sooner or later, might as well be sooner
Old May 13, 2021 | 06:57 PM
mist979's Avatar
mist979
Thanks Aklim. I have thought about getting an OBD1 scanner for this car. I have a few good OBDII scanners but nothing for OBDI. I might be selling this car though after I get it working properly. My original goal was to get a gen 6 Camaro when my truck got paid off. Truck is paid off next month, I bought my vette after I'd had that dream and that has changed my goals to now want a newer vette. Looking at c6's now. If I do that I may never need the OBD1 scanner. We'll see though. Plus 1320 website shows them all out of stock.
Old May 13, 2021 | 07:49 PM
aklim's Avatar
aklim
Maybe someone near you can lend you one. I would if we were near to each other.
Can't say I blame you for wanting newer. I am looking at the C6 or C7 myself and trying to see what I want and investigate what I need to do to sell the C4
Old May 13, 2021 | 09:34 PM
mist979's Avatar
mist979
Thanks Kevova, but I'm having trouble finding those posts.
Old May 14, 2021 | 08:17 AM
aklim's Avatar
aklim
You want to make me a deposit and I will lend it to you. I have 2 other different ones.
Your phone must be Android and not a fruit phone for it to work.
Old May 14, 2021 | 04:20 PM
mist979's Avatar
mist979
Thank you for that offer. I might take you up on that. For now though, if I feel pretty good about the right place to send my ECM for rebuild, I'm going to go ahead and do that anyway. Especially if it's only a few hundred $$.
To 1992 ecm
