Fuel pump relay getting no power
Is there +12 Volts on pin C during the 2 second Prime? (Connect your meter between Pin C and a good ground, and cycle the key). If = Yes, the ECM signal is getting to the relay.
Connect your meter between a (B+) terminal on the alternator or battery and Pin B on the relay. This checks the ground circuit for the relay coil. Is the ground good?
Does the relay "click" on then off for the prime? (This indicates the control-side circuit is functional, but the contacts in the relay may still be bad).
If all of the checks above test good, the relay is bad. In this day and age of "test by substitution", and chain stores honoring returns for any reason, the likelihood of getting a bad (or even the used part returned for credit) has gone way up. Especially from a chain store.
Start at your battery and be sure it is reading roughly 12 volts minimum without anything turned on. Now go to the battery Positive cable at the battery Positive Terminal. Be sure it is tight and clean. From this point there should be a RED wire that goes off to the drivers side behind the battery under the side panel it attaches to a Point on the frame. The post it attaches to should be easy to find as on my 1988 it has Seven Fusible Links ALL getting their power here. The post is not actually attached to ground and when you put as meter on it you should see battery voltage.
Your 1985 might be different physically but the Fusible Links need +12 VDC fed to them. I have found corrosion on the post that caused a serious voltage drop inside the car. If your Fusible Links are okay and you are getting 12 Volts move on to the fuse box and check for 12V there as well.
The fusible Links were GM's last line of protection from burning the car down. It is wise to check them for continuity if you are having a tough problem. On my 1988 I routinely check that post now that I am aware of the issues it can cause.
One One Corvette I actually found "Bad Fuses" that were causing the problems. They were aluminum and they had no continuity unless you scraped the surface.
Clean battery connections are vital on today's cars.
Good Luck!
Good Luck!
