86 no crank issues
Old May 27, 2021 | 06:36 AM
Vinvette86's Avatar
Vinvette86
7th Gear
Default 86 no crank issues
So I have had the starter and keys changed out and it is still not working. Any ideas on what this might be. The only things that have been done to it since I got it was a new fuel pump and and oil change.
Old May 27, 2021 | 11:53 AM
Mrvettenick's Avatar
Mrvettenick
Does it crank?
Old May 27, 2021 | 03:43 PM
Incorvettei's Avatar
Incorvettei
Did you get the appropriate key? 86 had VATS systems that read the resistance of the key. Won’t start if resistance isn’t right
Old May 27, 2021 | 05:23 PM
Vinvette86's Avatar
Vinvette86
7th Gear
Originally Posted by Mrvettenick
Does it crank?
no it is no crack and no start
Old May 27, 2021 | 05:24 PM
Vinvette86's Avatar
Vinvette86
7th Gear
I'll have to check with the guy doing it.
Old May 27, 2021 | 07:27 PM
CorvetteRules's Avatar
CorvetteRules
Why did you change out the key?? and did you change the starter to just throw part at it??
Old May 27, 2021 | 07:34 PM
Mrvettenick
OK, when you try to start it, does the security lamp flash?
Old May 27, 2021 | 07:57 PM
Vinvette86's Avatar
Vinvette86
7th Gear
When it did come on before it died it went very slow. I got the battery charged and no luck
Vinvette86's Avatar
Vinvette86
7th Gear
no light and I have no error code light either
Old May 27, 2021 | 08:06 PM
Mrvettenick
OK, So it did start before you did any work?
Old May 28, 2021 | 01:52 AM
Vinvette86's Avatar
Vinvette86
7th Gear
yes but intermediate starting and now able to start.
To 86 no crank issues
