Need some Help. What am I doing wrong? All work done IAW 1985 Corvette Shop Manual. I am just going to list the things and the way I did it. R12 System worked before rework. Removed and replaced everything.
New Compressor
New Condenser
New Acum/Dryer
New Evaporator
All new Hoses
New Orafice
Installed orafice (long screen towards condenser) all
New equipment/ hoses/Flushed, Dried and Vac. Blew shop air through all connections no blockage. Vac held for 12 hours
Installed Ester oil
3 oz in compressor,
2 ounces in Dryer,
1 ounce in condenser
1 ounce in evaporator
Charged
Used gages to fill from low side
High side valve closed
Filled 2 3/4 cans of R134a
Compressor started and cycles
Does not get cold on any vents or any lines getting cold just HOT.
Low pressure gage reads 80 psi and High side reads 150 psi. All lines are hot
Took system apart again and found:
No oil in Compressor
No oil in Dryer
No oil in Condenser
All oil in bottom of Evaporator
Repeated everything above. Ordered a new dryer will install and start again to fill.
Thanks for any input. My hair is getting gray! Art
Thank you for the no responses. Anyway I did everything a listed above again and got 47 degrees a center vent. All pressures are in accordance with the 1985 Corrvette shop manual. Thanks again
Not everyone here (myself included) is an AC Expert. Your question requires an answer from a true expert. Maybe did not give it enough time. Maybe could have done a search for AC posts and found the name of an expert here that you could have sent a PM to. I am sorry I did not respond right away with the statement, "I don't have a clue". Dan
