Need a recommendation.....
Old Dec 16, 2002 | 02:55 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Need a recommendation.....
I need to get my wheels balanced and an alignment...I want it done carefully (rims) and correctly...I am located on I-4 about halfway between Orlando and Daytona Beach so either city works....thanks all...
Dan
Old Dec 16, 2002 | 06:10 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Need a recommendation..... (golfboy1)
I see a lot of C4's around here..surely someone knows a place..
Old Dec 22, 2002 | 07:23 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Sorry no one gave you some help.....If you were out here in Southern CA. I would certainly help....
Sorry....but hang in there someone will post...
tony
:eek: :eek: :eek:
Old Dec 22, 2002 | 08:14 PM
dlmeyers's Avatar
dlmeyers
Default Re: Need a recommendation..... (oldace84)
Check with Rogers Corvette Center in Orlando. Ask them for a recommendation. Of course, most of their stuff is under 5000 miles but I suspect they have a preference.
You may choose to study up on camber, caster, toe-in/toe-out, rear wheel thrust angles, etc. Always get them mixed up. Ask the shop for the start and end settings. Some may provide a print out sheet. Prefer those.
On tire balance, the clip-on weights occasionally come off at high speed. I now prefer the inside stick ons. Some shops may not do the dynamic balance with stickys. Have seen this. Maybe equipment dependent.
As far as balancing equipment, Hunter model 9000 and above. The Hunter line has been around for a long time. Alignment and balance, look for heavy, well used equipment. Not the cheap stuff.
Hope things work out. Wish I knew somebody down there.
dlmeyers 90 coupe zf6 3 speed shocks
To Need a recommendation.....
