Just made the SuperPro bushing kit purchase....
Old Jun 15, 2021 | 04:39 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default Just made the SuperPro bushing kit purchase....
Been doing quite a bit of research on the SuperPro bushing kit for my 94 Z.....alot of great info here in the Tech Section.....just spoke with C&S Corvette and they are back in stock as of about a hour ago....so if anyone was or is thinking about it....now would be the time.....just placed my order about a 1/2 hour ago....since the 94 is already apart....hopefully the install will go well.... Suspension Bushing Kit, Late 1988 - 1996 Corvette – Corvette Parts Center
Old Jun 15, 2021 | 06:12 PM
ajp01's Avatar
ajp01
Thanks for the info; I've just pushed the button on my set as I'll be doing that work soon both front and rear.
Old Jun 15, 2021 | 06:46 PM
74 LS4-454's Avatar
74 LS4-454
Glad to have helped.....I love spending everyone else's money besides my own.....lol.....my front end is just about totally apart and has been for awhile....as I am doing other work as well....hopefully this will go as smooth as possible....will also be interesting to follow your progress as well....
Old Jun 15, 2021 | 07:51 PM
Hawkeye56's Avatar
Hawkeye56
Suggest have Lyle put in three or four additional grease packs, You only get two with the kit.
If you do not have a 12 ton hydraulic press I highly recommend a $100 HFT press and go to a machine shop and pick up a couple of 3:4 to 1inch plate steel for additional stacking plates.
One last trick is use a short 3:8 extension put in a large socket up side down so the extension goes down into the bushing and you have a flat surface to press on.
Hope this helps.
I am just getting back to my project of bushings and a lot of other items.
Thanks Hawkeye56
Old Jun 18, 2021 | 03:50 PM
74 LS4-454's Avatar
74 LS4-454
Hope this helps.
Thanks Hawkeye56
Package already left Hawkeye56.....scheduled to be here on Monday the 21st.....my friend Chris has the HF press out at his garage....so I am good there....and he may also have the steel plate.....been following your posts and others....and will be rereading them for sure.....appreciate the reply and tips....still have to remove the control arms....working on that this afternoon.....
Old Jun 18, 2021 | 04:14 PM
Hawkeye56's Avatar
Hawkeye56
I believe that the silicone caliper grease with TPE is the same grease. The Super Pro Representative told me that. The grease I received from Lyle was clear,, The grease that I purchased from the Rep, when I ordered the front sway bar bushings are colored black.
The package says premium bushing grease.
Thanks Hawkeye56
Old Jun 18, 2021 | 04:22 PM
Hawkeye56's Avatar
Hawkeye56
Are you doing front control arms and ball joints?
Thanks Hawkeye56
Old Jun 20, 2021 | 12:10 AM
74 LS4-454's Avatar
74 LS4-454
Thanks Hawkeye56
Yes I am doing the front control arms and most likely the ball joints.....
Old Jun 21, 2021 | 09:56 PM
74 LS4-454's Avatar
74 LS4-454
Just arrived today.....should be interesting....
Old Jun 21, 2021 | 10:02 PM
ajp01's Avatar
ajp01
Sweet!
Old Jun 23, 2021 | 02:01 PM
ctmccloskey's Avatar
ctmccloskey
Now comes the FUN part....
Nice looking parts, my polyurethane bushing are over 25 years old and still squeaking on both C3 and C4! Be sure to let us know How you like the SuperPro brand. I might have to replace the ones I did decades ago.
Good Luck and don't hesitate to cut the old ones with a saw if you have to. I used a sawzall and saved some time. One person told me to burn the out with a torch but the clean up might be more that I want to deal with. It is a GREAT time to clean up your suspension parts and really make your Corvette shine.
Old Jun 23, 2021 | 04:46 PM
Furias15x's Avatar
Furias15x
Hello,
I did mine with the red fully poly bushings and the rear dog bones squeaked pretty badly. I didnt have enough grease. I was very liberal with my application trying to stay away from the squeaks. I red on their site you can use marine grease. It has the sticky properties like that silicone grease. I got some from autozone and re-did the dog bones and now its nice and quiet. So that is an option.
Old Jun 23, 2021 | 10:19 PM
74 LS4-454's Avatar
74 LS4-454
Yes a great chance to cleanup the suspension which I already started awhile ago...as the front end is totally apart on my 94....so may take a little extra time to get it completely done...as there is alot going on here....lol..also appreciating all of the tips... .
Old Jun 24, 2021 | 11:10 PM
moonstation2000's Avatar
moonstation2000
Have fun, I did mine in early spring. I found that using a ball joint press was a good way to remove and install most of the bushings. I only needed the big 20 ton press for a couple of them, like the front control arms.
Old Jun 25, 2021 | 01:11 PM
ctmccloskey
Hello there 74 LS4-454,
I saw that your Corvette still has the rubber hoses going from the individual calipers. These hoses are only good for a period and then can act up. I bought a set from Classic Tubing that have the stainless steel braided jacket over the rubber lines. They make the brakes even better as they do not expand when you apply the brakes. The one thing to look for however is to be sure that they are D.O.T. Approved. There are sets being sold that don't have the D.O.T. Approval and I would avoid them.
I replaced the brake hoses on both of my Corvettes and I love the difference as it makes the brake pedal a bit tighter.
That is a beautiful Corvette you have there! It will really be nice to drive once the new bushings are all in place and you are on a winding road! My old Poly bushings like to be lubricated or they start to squeak. Mine were made before they got smart and included a lubricant into the mixture.
Old Jun 25, 2021 | 01:23 PM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
I just did this job on the rear of my '85. It wasn't too bad, I'll try to jump in and help if you need anything.
Beautiful car, looks really great! Good luck on this one.
Old Jul 8, 2021 | 03:06 PM
74 LS4-454's Avatar
74 LS4-454
Thanks ctmccloskey.....yes getting rid of the old hoses....and I do have an AC Delco replacement rubber hose set still in the boxes....I would imagine that they are DOT Approved....will check that out again....and will check the braided hoses out...thanks for the tip and the compliment on my 94....
Hello Bfenty.....thanks and appreciated....will definitely ask questions along the way.....and thanks also for the compliment on the 94.....
To Just made the SuperPro bushing kit purchase....
Old Jul 8, 2021 | 03:10 PM
74 LS4-454's Avatar
74 LS4-454
Hello moonstation2000.....I'm always having fun....lol....especially when you have 2 Vettes apart as opposed to just 1....lol.....hope I don't need the big press to remove anything....we shall see....still more to do....
Old Jul 8, 2021 | 03:41 PM
74 LS4-454's Avatar
74 LS4-454
Getting things done slow but sure.... steering knuckles are now cleaned and replacing the hub bearings....one side done...
getting a control arm bushing removal kit tomorrow....so we'll see how that goes...
One cleaned....
One side completed
Hub bearing before install...
Backside...this unit is ready for install....
Old Jul 9, 2021 | 12:02 AM
moonstation2000
It shouldn't be too hard to remove the old bushings, all of mine came out fairly easily. I only needed the big press on the bigger bushings for fitment purposes, not because I needed the extra pressure. It was definitely used on the front control arms.
That was a joke about the fun part, I found the job to be a bit of a pain at times. There were definitely a couple of new bushings that didn't want to go into their new homes that I had to throw a lot of curse words at... Luckily beer was there to console me and calm me down lol
