Throttle Body Coolant bypass.....
Old Dec 16, 2002 | 09:32 PM
C4kid94's Avatar
C4kid94
Default Throttle Body Coolant bypass.....
I was thinking about doing a TB collant bypass and i had a few questions.....
-Will this negitivly affect my engine or cause damage
-how much HP will I gain
-And I would really appreciate maybe some pictures of how you did it or some other info or advice you may have
Old Dec 16, 2002 | 09:51 PM
94redrag's Avatar
94redrag
Default Re: Throttle Body Coolant bypass..... (C4kid94)
I've considered this also, but in the Mid-America catalog its says something about "not recommended for use in below freezing temperatires due to possible throttle body icing". Does this mean if I drive my car in winter time tempertures that I'll have problems?
Old Dec 17, 2002 | 12:02 AM
MrCrowley's Avatar
MrCrowley
Here is another thread I recently started about the same topic, hope it helps you out some.
http://forums.corvetteforum.com/zerothread?id=452819
Old Dec 17, 2002 | 12:08 AM
vader86's Avatar
vader86
It causes no problems or damage to the engine. So long as you dont drive in near zero temps. And in FL youll never ever have that problem.
Its a couple to 5hp gain, no more than that though.
All you have to do is disconnect the two hoses leading into and out of the TB and mate them together with a pipe and 2 clamps. Thats it.
In extremely cold weather, and i mean sub-zero or very slow cruising in just-above-zero temps, the coolant is meant to heat up the TB and get the plates hot so they cant freeze. Only problem is that ive never seen or heard of anyone ever having them freeze. Of course, once the engine gets even slightly warm, they cant freeze anyway because the engine transfers the heat quickly.
Old Dec 17, 2002 | 12:10 AM
Goody's Avatar
Goody
Default Re: Throttle Body Coolant bypass..... (94redrag)
This was the only reason the coolant flows into the TB, was to prevent ice build up and a stuck throttle in severe cold. If you don't drive in the really cold temps, there isn't much risk if any. Don't expect to feel this gain, but it will be there little by little.......
Old Dec 17, 2002 | 12:20 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
I forget the site but some F-Body guy dynoed after doing the bypass and there was a 3 or 4 hp gain. Nothing huge, but considering it's free why not :yesnod:
Old Dec 17, 2002 | 06:34 PM
C4kid94's Avatar
C4kid94
thanks for the help :steering:
Old Dec 17, 2002 | 06:57 PM
CowboyNVette's Avatar
CowboyNVette
Its not the fact that its only a 3 hp gain but if you keep finding these little 3 hp gains they all add up. ex if you find 10 small hp gain additions to your car then you all of a sudden have a 30 to 40 hp gain. :eek:
Once your engine warms up to temp wouldn't the throttle body be warm enough to keep from icing? I have always thought something like this was only good for temps up in the extreme northern part of the US or Canada but if you live anywhere in the central or southern US then you shouldn't have to worry about this change. I haven't done this yet but I will :smash:
Old Dec 17, 2002 | 11:43 PM
vader86's Avatar
vader86
Default Re: Throttle Body Coolant bypass..... (CowboyNVette)
exactly
:yesnod: :yesnod:
To Throttle Body Coolant bypass.....
