89 Corvette Horn
Old Jun 22, 2021 | 09:34 PM
DM89's Avatar
DM89
Default 89 Corvette Horn
89 C4 Corvette, Took the steering wheel off about two months ago to replace key switch because of a lost key, I put it back together today and went to honk the horn and it didn't work, I used a wire brush and brillo pad to clean all of the contact points, I don't know if cleaning them changed anything or I just wasn't paying attention but when I press the horn all I hear is a clicking sound in the dash, and I tried all key switch positions, also the car doesn't run yet because fuel tank and injectors are out. Thanks in advanced
Old Jun 22, 2021 | 09:42 PM
s carter's Avatar
s carter
How is the battery? Have you tried to put a basic test light or DMM on the horn Leads. I have seen unused horns corrode and not work a little smack and they may come to life
Old Jun 22, 2021 | 11:03 PM
aklim's Avatar
aklim
As to your horny problem. Test light on the horn wires. If you don't get anything, go backwards. If you do, new horns
To 89 Corvette Horn
