Speed bleeders basic question
Old Dec 17, 2002 | 12:40 PM
kittmaster's Avatar
kittmaster
Default Speed bleeders basic question
I was looking at some old threads about these devices and really just have one question. Besides the fact that they make bleeding the lines easier, what is the point? Once air is removed from the line it should never come back unless a mechanical malfunction occurs. So what is the thinking behind these bleeders vs just doing a job right the first time? Any other insite or reasoning would be helpful :confused:
kitt
Old Dec 17, 2002 | 01:06 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Re: Speed bleeders basic question
First off, at the very least brakes should be bled at least once a year for a normal car, and after every event if you track your car. For me this means bleeding the brakes once or twice a month (sometimes more). The speed bleeders allow me to do this easily and quickly by myself. Even if your car is just a street car, the time you save (and not needing an extra person) once a year is worth the price. Also, air and/or moisture can and will enter a properly functioning brake system through normal use or even if the car sits in the garage all year. Or if you have a panic stop, or several heavy stops (going down a hill/mountain) you could boil the fluid and introduce air into the system.
Hope this helps.
Old Dec 17, 2002 | 01:12 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Speed bleeders basic question (kittmaster)
I just bought two pair at at Pep Boys. $9.95/pair, same price as Summit online.
Main thing is they make bleeding the brakes a one man job instead of two man. You have to loosen them a 1/2 turn or so to open them they let fluid and air out but not back in.
Old Dec 17, 2002 | 01:13 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Speed bleeders basic question (EvanLT1)
:iagree:
Old Dec 17, 2002 | 01:18 PM
kittmaster's Avatar
kittmaster
Never really thought of it that way. Always knew it was a closed loop system so to bring air in under boil or hard breaking never occured to me. Thanks for the heads up
Chris
Old Dec 17, 2002 | 07:50 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Speed bleeders basic question (Lone Ranger)
:cheers: I have the speed bleeders on the Vette and they work well...but so does gravity bleeding and that's a one person job as well.
Just had to do an "emergency" gravity bleed on my Z 28 over the weekend (bad brake hose) and no help available. Gravity bleed worked fine, just wait till you have a steady stream of fluid (not sputtering or intermittent). Slowly close bleeder and tighten it.
Jack :steering:
Old Dec 17, 2002 | 11:36 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Brake fluid is useful for about 2 years tops!
The term "bleed" is used often. Bleeding is required when air is introduced into "good" fluid due to maintanance or failure of the system.
Brake fluid needs to be FLUSHED every two years, at least, under normal useage. Complete flush, every drop. There have been so many posts on this forum over the years regarding brake problems that, IMO are totally due to old fluid, or improper bleeding/flushing that it almost defines the largest braking problem on the C4 posted here.
There are lots of ways to flush the fluid, speedbleeders are one way. Proper proceedure / knowledge is required to bleed / flush the system. Speedbleeders help with one common problem : letting air in from the bleeders. Still not fool-proof.
Old Dec 18, 2002 | 12:00 AM
jefft84's Avatar
jefft84
Default Re: Speed bleeders basic question (PeteL)
:iagree: :iagree: :iagree:
GREAT POINT PETE
I prefer the Pheonix Injector for bleeding/flushing because it will do vaccum or pressure which is great for clutches.
Old Dec 18, 2002 | 09:06 AM
Lone Ranger
Is there any info on the procedure to follow for flushing brake fluid on a C4?
I have 4 speed bleeders to install and want to flush the fluid out. My fluid is believed to be original from 1995 (33K miles on car). I want to flush it out and pour in some Valvoline SynPower DOT 3/4 fluid. Not after the top racing fluid, just the best off the shelf parts store fluid, and the SynPower stuff is supposed to be pretty good. I did all four brakes with new pads last week so this should round out the brake job.
Old Dec 18, 2002 | 09:27 AM
EvanZR1's Avatar
EvanZR1
If it's the original fluid (or even just 3 or 4 years old) you'll know. The fluid will be almost black and you'll easily be able to tell when new fluid starts coming out at each caliper. I can never remember for sure, but it seems like the proper order is:
passenger's rear
driver's rear
passenger's front
driver's front
Make sure you keep the brake resovoir full while bleeding the system. You can keep an eye on it if you pump the brake pedal while standing, or just only pump 3 or 4 times and then check the level. You won't believe how much better the brakes will feel with fresh fluid. :D
Old Dec 18, 2002 | 10:30 AM
jefft84's Avatar
jefft84
:iagree: That sequence is fine, I would reccomend removing the old fluid from the master cylinder and filling with new fluid before you start flushing. This cuts your time down and helps keep less dirt/ contamination from passing through the master cylinder. Just use the turkey baster from the kitchen to suck out the old fluid from your master cylinder it will be next thanksgiving before the wife knows its gone.
Old Dec 18, 2002 | 10:33 AM
EvanZR1's Avatar
EvanZR1
Default Re: Speed bleeders basic question (jefft84)
I new I left something out, thanks for bringing that up. It's amazing how many people I've had over in the garage and they wonder what the turkey baster is for.
Old Dec 18, 2002 | 11:43 AM
fixvet's Avatar
fixvet
I've been watching this thread with interest. Question is........what brand/type of brake fluid is best for my stock '88 brake system with 163,800 miles?? My fluid is pretty dark, and it may be original for all I know. I've had the car two years, but I know the previous owner changed pads at least once according to his records, but I don't know about the fluid.
Old Dec 18, 2002 | 11:49 AM
EvanZR1's Avatar
EvanZR1
If it's just a street car, then any DOT 3/4 fluid will work fine. I personally prefer Valvoline or Performance Friction because they have higher boiling points, but then I also race my car so that's really important to me. Some folks who race will spend extra money for specialized fluids, but I'd prefer just to bleed the brakes more frequently and use a good reasonably priced fluid.
Old Dec 18, 2002 | 01:57 PM
Lone Ranger
The Valvoline SynPower fluid in the gold bottle is supposed to be about the best stuff you can find on most franchise/chain auto parts store shelves. Specialty fluids are no doubt better, if you race or auto cross though. Synpower is purported to exceed DOT3, and DOT4 standards (but not rated as DOT5).
On a side note, I was telling some co-workers about how I intend to flush my brake fluid because its still original and they gave me these blank stares. They'd never heard of changing brake fluid, yet they're always mouthing off trying to show that they know it all about maintenance, and performance.
Old Dec 18, 2002 | 06:48 PM
Blk-94's Avatar
Blk-94
Uhm.. I have a question.. With all this brake bleeding going on. :) Were can you dispose of the used fluid? I've got a peanut butter jar's worth sitting in the store room not knowing where or how to get rid of..
Old Dec 18, 2002 | 09:00 PM
DDMMCPO's Avatar
DDMMCPO
Default Re: Speed bleeders basic question (Blk-94)
My .02,
Took mine to the local hazardous waste collection site with all of my old oil coolant. Didn't cost anything other than time and the gas to drive my wife's SUV to the site. Good Luck.
Bruce :chevy
To Speed bleeders basic question
Old Dec 18, 2002 | 10:38 PM
JasonL's Avatar
JasonL
Pep Boys will take hydraulic oil (brake fluid) as well as motor oil. But not every schmuck behind the counter realizes this, so you might get rejected...check with a few different locations. None of the other parts stores in this area seem to take brake fluid.
Your city or county should have a hazmat disposal facility which will take just about all automotive fluids as well, no charge to residents.
Protect the environment...dispose it properly :cheers:
Old Dec 18, 2002 | 10:46 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Speed bleeders basic question (JasonL)
Wait, I'm missing something here. What's the difference between gravity bleeding and using speed bleeders?
[Modified by NUckINg FuTS, 9:46 PM 12/18/2002]
Old Dec 18, 2002 | 11:27 PM
larryfs's Avatar
larryfs
that vavoline or the castrol LMA is the best stuff around. all (most) of the race fluids ABSORB MOISTURE so fast, it's a waste of money. but of course, no one realizes that, and they spend mega money for nothing.
Larry - who has tried but never boiled the castrol LMA :D
