Power window motor: replace or rebuild?
Old Dec 17, 2002 | 02:39 PM
Thud's Avatar
Thud
Default Power window motor: replace or rebuild?
I think my driver-side power window motor is about toast. A couple nights ago it went down, but slowed and stopped on the way up, then wouldn't budge.
I "fixed" it by slamming the door shut with the window-up switch pressed, which jarred the thing into working again.
Are these motors rebuildable (I'm assuming new brushes and a clean commutator might work) or do I need to replace the whole assembly?
It's a '93 as my sig shows.
Old Dec 17, 2002 | 07:06 PM
greg84's Avatar
greg84
Default Re: Power window motor: replace or rebuild? (Thud)
hi,for the amount of work on installing your motor go for a quality rebuilt or factory new.any well stocked auto store will have the part for you.good luck greg84 :cool:
Old Dec 17, 2002 | 07:38 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Power window motor: replace or rebuild? (greg84)
:cheers: They should cost under $100 new. I think it is a standard motor for most GM Cars so check before you fall for "vette pricing" Contact Jeff Koop for best advice and prices
Jack :steering:
Old Dec 17, 2002 | 11:09 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Power window motor: replace or rebuild? (jackdaroofer)
Replace it. Cheap and easy enough. Goes up like new. :)
Old Dec 19, 2002 | 12:51 AM
R23HTC's Avatar
R23HTC
Default Re: Power window motor: replace or rebuild? (blk90rdstr)
Got my drivers side from the Last Detail. http://www.tld-corvette.com/ $75 Brand new GM. That was before I knew about Jeff Kopp though. I'd check them both.
To Power window motor: replace or rebuild?
