max compression ratio???
Old Dec 17, 2002 | 07:43 PM
SonnyinVA's Avatar
SonnyinVA
Default max compression ratio???
any input as to the max compression ratio i can run in a bad butt 409 LT4 and still run pump gas??
i'm considering using Evans Coolant... it's the non-aqueous propylene glycol, any input about that?? it supposedly allows you to run higher compression without detonation... here's the link if anybody cares to look...
http://evanscooling.com/html/home1.htm
thanks!
sonny
Old Dec 17, 2002 | 08:09 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: max compression ratio??? (SonnyinVA)
A friend of mine ran about 12.5:1 in his 396 LT1 for a little while. There was no apparent knock but the computer could have been retarding his timing a little bit, we never got the chance to data log it.
12:1 is probably about as high as you would really want to go for the street. The reverse flow cooling of the LT1/LT4 helps a lot, but I still wouldn't try to take it much further.
Old Dec 17, 2002 | 09:09 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: max compression ratio??? (Nathan Plemons)
Cam timing has alot to do with it, but to play it safe on pump gas, I would stay under 11.25:1 compression
Old Dec 17, 2002 | 10:24 PM
superlund's Avatar
superlund
Default Re: max compression ratio??? (tpi 421 vette)
I'm running 11.54 CR on a 355 CI motor, no knock counts yet while under load W/93 octane. :D
Keeping the deck height/quench to a bare minimum will help eliminate any chance of detonation W/ high comp. ratios. :)
Old Dec 17, 2002 | 11:37 PM
vader86's Avatar
vader86
Default Re: max compression ratio??? (superlund)
Try to shoot for compression just below 11.5:1
Old Dec 18, 2002 | 08:48 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: max compression ratio??? (vader86)
Mine is gonna be in that range too...12.1-12.5:1
I'll let you know soon :D
Old Dec 18, 2002 | 08:57 AM
SkarodoM's Avatar
SkarodoM
My buddy Chuck Riddeck had a great writeup on his tests of the Evans system, and if I recall correctly, it worked pretty well.
FWIW, though it depends somewhat on the cam, you've got to take into account diminishing returns. IMO run ~11-11.5
Old Dec 18, 2002 | 09:11 AM
GlockLT4's Avatar
GlockLT4
:yesnod: my 11.55:1 was a bit much ... in hot weather during the summer i had some problems with knock .. with 93 octane w/ octane booster too.
Old Dec 18, 2002 | 02:39 PM
SonnyinVA's Avatar
SonnyinVA
Default Re: max compression ratio??? (GlockLT4)
why do you say diminishing returns? cuz you have to take out too much timing??
where is that write up about evans cooling systems??
thanks guys
Old Dec 18, 2002 | 05:57 PM
SkarodoM's Avatar
SkarodoM
Not only giving up timing for CR oftentimes, but pumping losses as well when you start to get that high.
I thought I had Chuck's writeup somewhere.. I'm tryin' to dig it up, it was pretty interesting :)
Old Dec 18, 2002 | 06:35 PM
sinistervette's Avatar
sinistervette
Default Re: max compression ratio??? (SkarodoM)
Camshaft choice will be a big factor in the amount of compression you will be able to run. Make sure you know your cam choice before ordering pistons/cylinder heads, and build your engine to compliment all the componants you want to use. A package designed to work together can be smaller than one that is mis-matched and give you much better results. You shoud be able to run well into the 12?-1 range without any troubles at all. I've done it with carburated street engines so a good management system should be even better! :cheers:
To max compression ratio???
