Oil cooler leaking
Old Jul 12, 2021 | 11:42 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Default Oil cooler leaking
It's on my '90.
Technically speaking, I bypassed it last year and completely removed the pipe and hoses to it.
But then I bolted the oil cooler itself back on for the time being afterward.
It's not functional, it's just there. Leaking now, though.
Can I just remove the whole thing along with the adapter and just screw a new filter into the block?
As memory serves, I think I can, just don't quite remember. But I'm not gonna crawl under there if not, so that's why I ask.
Thanks!
Old Jul 13, 2021 | 12:22 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
yes but!
edit, you do need shorter bolts as demonstrated below. perhaps the can be cut to length
Old Jul 13, 2021 | 12:37 AM
ajp01's Avatar
ajp01
Where's it leaking from? If it's just the oil cooler seal up top, that's very much like a square-section oil filter gasket. Your option though, you can take it off or leave it and replace with a new seal.
Old Jul 13, 2021 | 01:56 AM
Natty C's Avatar
Natty C
Originally Posted by VikingTrad3r
yes
Oh, good. I thought so but wanted confirmation before crawling under there. Thanks!
Old Jul 13, 2021 | 02:08 AM
Natty C's Avatar
Natty C
The gasket is bad. That's where the leak is. I have that squared gasket but since I've aready removed the rest of the oil cooler stuff, I'm just gonna take it off for good and store it with the rest of the oem parts I've replaced. As I'd mentioned, it's just there. It's not functional. I'm using full synthetic anyway. I haven't really noticed much of a difference with or without the cooler over the last year or so. Nothing meaningful anyway.
Now I've got a new oil pan here that I may very well not really have to replace just yet. Will see.
Old Jul 13, 2021 | 10:23 AM
Natty C's Avatar
Natty C
Bah.
I knew better.
Shoulda stuck with my instinct.
What a waste of my time.
In case anyone else runs across this thread, you have to swap out the studs with shorter bolts (which I don't have) and reinstall the adapter, then the oil filter.
So the correct answer is, no, you can't just screw the filter straight into the block without modification.
Don't waste your time crawling under there unless you first aquire the shorter replacement bolts after you figure out the pitch on them, otherwise you have to stop in the middle of doing it and run all over town trying to find the right bolts. I dunno about anyone else, but I hate stopping in the middle of doing something over dumb stuff.
Old Jul 13, 2021 | 11:53 AM
VikingTrad3r
Oil Producer
could you have cut the bolts to length?
i did it the other way. i started without one, and added one.
i guess the longer bolts i required came with the used kc4 i purchased.
id think thats not too tall of an order...to find the proper bolt length. would cutting the bolts have worked out if a person was able to cut?
Old Jul 13, 2021 | 01:08 PM
Natty C's Avatar
Natty C
I went and bought a couple of 5/16 - 18x1 grade 8 bolts after I got done pissing and moaning about it earlier. I just wanted to cuss at something, so came on here to btch about it before I headed out.
It's done now. I finished it up a couple hours ago. If it wasn't nearing a hundred degrees with all of the humidity I probably wouldn't have started kicking stuff around. lol.
But, yeah, guess they could be cut but then what if you want to reinstall the thing later for whatever reason.
Anyway. Thanks for the input regardless. I knew about those studs, but just didn't remember exactly what it was that had to be modified. Just dumb stuff.
Technically speaking, yes, the filter does just bolt right back into the block, just have to swap out the cooler adapter bolts to the shorter ones if you're working with existing parts.
Old Jul 13, 2021 | 01:29 PM
VikingTrad3r
Oil Producer
glad u got it sorted. when i was starting out on the track, i had an 86 base 4+3. It had no kc4. i ran mobil 1 5w30, had a factory rad that was working well. installed a kc4 and that little heat exchanger helped keep my temps within 9deg c (higher) of my coolant. i was fairly impressed. normal street driving it was always within 7deg c of coolant.
i track a 91zr1 now, it has a much larger air cooled traditional oil cooler. the oil temps are always waay below coolant temps with that setup.
that kc4 gets a bad rep but i wouldnt take my L98 to the track without it, if i didnt already have an air/oil cooler. Completely different story on the street im not sure its necessary where i live! Sounds like its pretty hot right now down south!
You mentioned yours was leaking. Was it leaking at the oring to the block? or was it leaking out the cooling chamber that the coolant flows through? cheers glad u got it sorted.
Old Jul 13, 2021 | 02:51 PM
Natty C's Avatar
Natty C
It was the squared off gasket that was spraying all over the wiring there next to the oil filter. The cooler itself was tight. The cooler was all that was left on the car as I'd already bypassed it and completely removed the pipe and input/output hoses last year. So now the entire cooler assembly is gone.
Oddly, that square gasket looked okay. Don't know why it was leaking.
I gave it a good run, got it up to a speed that I cannot admit to on here, but on a safe straightaway none the less, away from other traffic. No leaks now.
So now I have this new oil pan I was going to have installed that I don't need. But I'll keep it around. I'll install it at some point. Now that I know I don't really need to replace it at the moment, I can do it myself at my own leisure.
The Mobil 1 5W-30 tends to stay around the same temp as my coolant without the cooler. Maybe a few degrees higher, depending on how I'm driving. Which was about the same temp it ran when the cooler was fully installed and operational. That's just regular driving, though, on evening cruises through the winding back aroads. Which is basically the most road time it gets.
Old Jul 13, 2021 | 03:01 PM
ajp01's Avatar
ajp01
It leaks because it cooks / bakes / hardens / shrinks, and then you're there. Same with the oil pan gasket eventually. I had the same issue as you with the cooler and I replaced that seal, installed a new Fel Pro blue silicone oil pan gasket, and it was a great help. Good luck with everything.
Old Jul 13, 2021 | 07:01 PM
VikingTrad3r
Oil Producer
im with u on the expensive but very good blue felpro oilpan gasket! its a shame its $ but i find the grey rubber ones get hard quick and the oldschool cork is an absolute nightmare to clean mating surfaces on.
To Oil cooler leaking
