Lowering front end
Old Jul 14, 2021 | 03:15 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Default Lowering front end
I lowered the front of my 95 ZR-1 a few years ago. I've decided it's too low. I cut the rubber on top of the Mono leaf spring. I can't remember how much I cut off. I'm hoping some one can tell me the thickness of the factory rubber that is on a stock spring.
Thanks for any help.
Old Jul 14, 2021 | 03:19 PM
Phobos84's Avatar
Phobos84
How much do you want it to come up?
Old Jul 14, 2021 | 04:32 PM
randy ransome
2015 C4 of Year
At least an inch
Old Jul 16, 2021 | 04:18 PM
randy ransome
2015 C4 of Year
I’m still needing some help on the thickness of the rubber on the top of a stock 1995 front mono leaf spring.
Please help a brother out?
Old Jul 17, 2021 | 02:47 AM
mcm95403's Avatar
mcm95403
I happen to have the front spring out of my 91 Z07. I believe all year C4 springs interchange. Mine measures 13/64" from the top of the spring to the top of the metal cap.
Old Jul 17, 2021 | 10:22 AM
randy ransome
2015 C4 of Year
I think you're correct about the springs being interchangeable. I really appreciate the information. I've got to get my Z back on the road.
Thanks Again
Old Jul 17, 2021 | 11:52 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Nice vette.
Last year's unmodified C4 of the year as I recall.
Old Jul 17, 2021 | 11:58 AM
95wht6spd's Avatar
95wht6spd
Make sure your shocks are not worn out and front is sagging, happened to me, and front became way to low, especially on one side.
Old Jul 17, 2021 | 07:23 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Did you cut the aluminum cushion mounts under the spring when you did it? I know I had to, to take up the space of the removed rubber so the spring mounts/bolts would hold the spring in place when I did the wife's 95 LT1.
Old Jul 17, 2021 | 09:54 PM
WVZR-1's Avatar
WVZR-1
Inspect the spring, measure and compare 'heights' using the FSM dimension points. In the '95 FSM these should be near 3-21. You want to after checking the spring for condition just confirm that they're equal side to side. Front springs are different '90 & '91, then '92+ for the fabrication of the ends where it meets the LCA. If dimensions are all equal side to side I believe you could fabricate a shim to stuff into the LCA pocket to raise the car. I'm quite confident of that. I believe you can do this without removing the spring or other suspension components. You won't need 1" each side!!
I suggested this to a fellow quite some time ago and he fought it for quite a while. It did ultimately correct his 'ride height' when he did it. I don't know that he finalized his with a fabrication but he did accomplish it using some available loose parts. This is a thread that summarizes his adventure. He's a 'great guy' and I'm sure could pass on to you some of his adventure and some shortcuts maybe.
https://www.corvetteforum.com/forums...-question.html
This is the contact patch of a '92+ front spring to the LCA
Old Jul 20, 2021 | 10:20 PM
randy ransome
2015 C4 of Year
I really appreciate the information. I'll study it tonight and see what I can come up with.
Thanks Again for the help!
Old Jul 20, 2021 | 10:30 PM
WVZR-1's Avatar
WVZR-1
You can't tell until you get into actually inspecting the front spring. Using the measurements is a real benefit to diagnostics, it just works. If there's no physical damage to the spring a shim into the LCA should solve your issues. Replace the front spring? Ultimately you might need to but I'd expect LCA shim to solve your issues.
Old Jul 20, 2021 | 10:52 PM
randy ransome
2015 C4 of Year
The spring is in good shape. I was just looking at my FSM about trim height. I've got lower profile tires than stock but I think I can come up with a height that will help raise it enough. I'm thinking, what you said about, the shim under the end of the spring would be the easiest way.
Old Jul 20, 2021 | 11:04 PM
WVZR-1's Avatar
WVZR-1
If you had access to a LCA to determine a correct fabrication it might be considered a large benefit. Do you have or could you 'close by' come up with a LCA to determine shape?
Old Jul 20, 2021 | 11:51 PM
mcm95403's Avatar
mcm95403
You sir, are an incredible encyclopedia of knowledge!
Old Jul 21, 2021 | 12:55 AM
rhandle's Avatar
rhandle
Default zr1
Thanks Again
It looks great ! What issues were you having?
To Lowering front end
