Trouble shifting through gears
Old Jul 19, 2021 | 03:52 PM
NoFear's Avatar
NoFear
1st Gear
Default Trouble shifting through gears
Hello,
I have a 1993 LT1 6-speed and have been having issues shifting through gears. A few months ago the pressure in the clutch pedal was lost so I replaced the slave and master cylinder. It drives and shifts fine through the gears at normal speeds. Ever since I did this work on the car though it does not shift from 4th to 5th starting at around ~40 mph. I can shift before that speed but not after it. I can shift from 3rd to 5th however with no issue. It did not use to have this issue. Does anyone know what may be causing this?
Thank you
Old Jul 20, 2021 | 10:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Shifting
Sounds like u still have air in the line between the master and the slave.
rebleed it and see if it improves
