Pigtail help....
Old Jul 21, 2021 | 12:54 PM
Morpheus92's Avatar
Morpheus92
Navigator
Default Pigtail help....
Good morning group,
Can anyone tell me where I can find a connector (see attached photos) for my windshield wiper motor/controller? Mine were shorted out this past Winter by some creature looking for warmth.
thanks for any advice
Old Jul 21, 2021 | 02:32 PM
WVZR-1's Avatar
WVZR-1
An ACD PT335/GM 12102668 will require minor modification to work. The original from GM was only an empty connector that you needed to add terminals and assemble. That was a 12020014. BWD and others should have an equivalent to the ACD/GM that should be available locally and also less expensive. It's been used by some here for a correction. This is an installed snapshot of it's use.
@DMITTZ David Mitten supplied the snapshot of it's use and I believe he used a BWD equivalent rather than the ACD/GM. Availability might depend much on your location.
Old Jul 21, 2021 | 07:29 PM
Morpheus92's Avatar
Morpheus92
Navigator
Thank you for the help...but I’m lost as to the BWD meaning.
Old Jul 21, 2021 | 07:39 PM
WVZR-1's Avatar
WVZR-1
BWD would be PT618 check local auto parts jobbers with any of those numbers mentioned.
Where are you located?
Old Apr 28, 2022 | 10:45 PM
Morpheus92's Avatar
Morpheus92
Navigator
Dallas area.
Old Apr 28, 2022 | 11:04 PM
Morpheus92's Avatar
Morpheus92
Navigator
Dallas area.
Thanks for the response. Luckily they only damaged the wires to the wiper module and parking light socket. Finding direct fits are extremely difficult.
Old Apr 29, 2022 | 07:00 AM
WVZR-1's Avatar
WVZR-1
The wiper module connector is no longer a problem? Fixed?
To Pigtail help....
By Michael S. Palmer | 2026-06-03 11:00:24
