C4 Headlights pods acting up
Old Jul 21, 2021 | 09:18 PM
quantum93blue's Avatar
quantum93blue
6th Gear
Default C4 Headlights pods acting up
So, I replaced both headlight motors 2 years ago, they've been working great since then. Last week the passenger side decided to not close completely. As I turn the headlight switch on and off it would correct itself, then another time I had to raise the hood and close manually. That's not my biggest issue with them. Coincidentally they won't open with just the switch now. When I wash it I usually open the drivers door, turn the lights on so they will rotate, dry them off then turn them back off. Now i have to start the car before they will rotate. That makes no sense to me unless its the actuator module?
Old Jul 22, 2021 | 11:41 PM
aklim's Avatar
aklim
With a car this old, I suspect it is the headlight pellets. I would get the 2 kits ready. Just in case. https://www.ecklerscorvette.com/1988...-358251-1.html
Old Jul 23, 2021 | 09:08 AM
quantum93blue
6th Gear
Thank you for your input aklin. With the motors being 2 years old (I bought new) that will be looked at as well. About a month ago I cleaned all the associated brackets and cams, then put a dab of grease on all the moving parts. Looking the other night I decided that wasn't the best idea. Every place I has greased was pretty dirty. So I went through the process again, this time wiping the parts after decreasing. I then noticed when the passenger side headlight didn't close or open all the way it seemed to stick or have something stop it. So i will be inspecting the brackets and mounting mechanisms closer.
To C4 Headlights pods acting up
