Need to replace
Old Jul 28, 2021 | 05:37 PM
941YYG's Avatar
941YYG
Default Need to replace
What is the part number for the shift linkage on a 1992 vette? I want to order one from rock auto just cant find it. Also would a later model shift linkage work on a 92 as well?
Old Jul 28, 2021 | 06:08 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Do you need the entire assembly, or just a component ?
Old Jul 28, 2021 | 06:24 PM
941YYG's Avatar
941YYG
entire assembly. Mechanic said it was called shifter linkage but 🤷‍♀️ the dealer doesn't have it
Old Jul 28, 2021 | 06:28 PM
941YYG's Avatar
941YYG
will this work?
Old Jul 28, 2021 | 06:50 PM
drcook's Avatar
drcook
The mechanic needs to tell you what is wrong. Cables are available, but finding an entire new assembly is going to be like looking for hen's teeth.
If you truly need the entire assembly, you could call Mark Mirrock at https://mirrockcorvette.com/ and see if he has one he could sell you.
But once again, you need to know exactly what you are asking for.
Old Jul 28, 2021 | 06:54 PM
941YYG's Avatar
941YYG
🤔 hmm yeah I'll give him a call. I got the cable and everything but we're just missing that part I guess this is where it gets difficult 😅
Old Jul 28, 2021 | 07:03 PM
KurtK's Avatar
KurtK
Corvette Central
I would call and verify the part number for your car.
Old Jul 28, 2021 | 07:41 PM
s carter's Avatar
s carter
Just wondering what is so wrong that it needs a pull and throw, there is not much that has not been brought up on this forum that hasn't been discussed or can't be figured out.
. If it is needed Mirrock is probably your best bet for a fair price
Old Jul 28, 2021 | 09:26 PM
941YYG's Avatar
941YYG
So if anyone is having trouble finding the part name it's called the shifter assembly.
Old Jul 29, 2021 | 08:40 AM
FostersPerformance's Avatar
FostersPerformance
I have one from an 88 I won't need. Pm me if interested. Dont know if they are the same.
Old Jul 29, 2021 | 09:13 AM
WVZR-1's Avatar
WVZR-1
'92 was before shift lock solenoid but park lock cable and neutral safety seem to be the same '92+ so I'd think likely '92+ could be made to work. OP ain't mentioned for fact what's busted so who knows. If someone had a '92+ that they could 'offer up' you could help the OP likely. GM SPO mentions '92 & '93 then a change for '94+.
Old Jul 29, 2021 | 11:36 AM
Fiberbundle's Avatar
Fiberbundle
What is the shifter failing to do that is causing your mechanic to suggest buying a new one. If it is that the button is hard to depress to move the lever you do not need to replace the entire shift linkage.
Old Jul 30, 2021 | 06:29 PM
941YYG's Avatar
941YYG
it's a 92 and yeah we finally figured out what it was called so it made it easier to find the part online 🤷‍♀️ I saw a 96 one too but didn't want to risk the parts not fitting. Now on to my wheels I need to make a new thread. On another thread I made I got the paint all scuffed up so I resanded my hood and got BGM0520 paint and it looked exactly like factory😎 👍. Too windy yesterday so I'm waiting on the weekend. On to wheels I want to redo those as well
To Need to replace
