I wouldn't mind having a motor that pushed more air. Though the blower motor connector seems to get really hot as the plug connector has gotten melty and burned over the years. Will probably eventually have to cut it off and crimp on a new plug.
I was also thinking of a 17 volt power supply that is 12 v input, 17 v output @10 amps.
that might speed it up.
or a different fan on the motor with higher pitched blades.
(might drag the motor down, or draw more amps)
Elaborate. Automatic or manual hvac? Does air blow out correct duct? Vacuum leak will cause air to blow at windshield or air doors can be slow to respond.
