LT1 fuel rail
Old Dec 18, 2002 | 08:08 PM
Stingray1970's Avatar
Stingray1970
Default LT1 fuel rail
How is the fuel pressure regulator and fuel line removed from the fuel rail. I've never had one apart and I don't want to damage it. Thanks for any imput.
[Modified by Stingray1970, 1:18 AM 12/20/2002]
Old Dec 18, 2002 | 08:16 PM
Stingray1970
Default Re: LT1 fuel rail (Stingray1970)
Sorry the puke was an accident
Old Dec 18, 2002 | 09:03 PM
ittlfly's Avatar
ittlfly
The fuel lines at the fuel rail are a quick disconnect fittings. You need to get the tool from your local auto supply to release them. The FPR is held on by a couple of small bolts and the fuel rail is attached to the intake by 4 bolts. Be sure to get new "O" rings for the FPR and put a drop of oil on them if you take it apart. Oil the male ends of the quick disconnect fittings too or they may leak.
Old Dec 18, 2002 | 09:59 PM
Stingray1970
Default Re: LT1 fuel rail (ittlfly)
Thanks for your help
Gene
Old Dec 19, 2002 | 01:50 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Gene, you can edit your post to remove anything in it. :cheers:
Old Dec 19, 2002 | 07:26 PM
ittlfly's Avatar
ittlfly
Gene
:cheers:
To LT1 fuel rail
