wheel size
Old Dec 18, 2002 | 10:57 PM
dream89's Avatar
dream89
Default wheel size
hey everyone, i see quite a bit of the c5 wheels on ebay. they are 17x8.5. will this size wheel fit on 275/40/17 tires?? i know the 17x9.5 wheel will fit but i wasnt sure about the 17x8.5
Old Dec 18, 2002 | 11:22 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: wheel size (dream89)
I answered your question in the C4 General and said yes but I found out something else to add....You can run them on some tires and some tires not. :confused: Your best bet is to go to www.tirerack.com and check out the specs on the tires you want to run. On GSCs Goodyear recommends 9" to 11" Rims....but on a Kumho it said 8.5" to 10.5"...so it depends on the tire you want to run
Old Dec 18, 2002 | 11:25 PM
dream89's Avatar
dream89
Default Re: wheel size (CowboyNVette)
thanks for the tip!! that helps a lot!!
To wheel size
