what sensor goes where?
my main question is can someone look at these pictures and tell me if I have all the right sensors in the right place, and if not what I need to replace.
Location: drivers side between piston 1 and 3 (does not have plug)
extra sensor that i cant find plug for
sensor that looks like it's supposed to go between piston 1 and 3 instead of the currently installed one (has a plug but wires are a few inches short)
thanks yall
The Top picture might be a temperature sending unit. Just out of curiosity try and measure the resistance between the sensors on the top and passengers side. It looks like a CTS where it is mounted. Is that the harness to the left on the picture with the Yellow and Black wires?
The second picture looks like a Cylinder Head Temperature sensor? I am not sure..
The third picture looks like it is a single wire type like the Knock sensor.
The fourth picture looks like your Sensor for between cylinders #1 and #3 as on mine the sensor is a single wire. The connector for this sensor is the same as they use on the Knock Sensors from what I have found.
The last picture is not your Aux Fan sensor, being three wire it might be the Coolant Temperature Sensor or something else.
If I am not mistaken there is a couple pages in the FSM that identify the connectors for you. That might be the best source!
I am not 100% sure that all those sensors came with the Corvette.
But then again maybe it's a 'Hybrid' sorta thing. OP hasn't mentioned squat except that he's no idea of where he's at!
11/20 he mentions it being "CARBED' by a PO! There ain't no help for the guy until he get's to 'THE REST OF THE STORY" His snapshots don't do 'squat'!
thanks
