painting Callipers
Old Dec 19, 2002 | 10:26 AM
aroulette's Avatar
aroulette
Default painting Callipers
How hard is it to pull callipers. What do I need to do to pull off. Is it as easy as it looks? 2 bolts? PLease give me explanation
Old Dec 19, 2002 | 11:52 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: painting Callipers (aroulette)
yep, its that "easy" .. 2 bolts.
the trick is that many times, those 2 bolts are tight as *&^%.
be sure to use some penetrating oil, and, even then, they will be tight. :eek:
for specifics, check out C-4 teck tips. There is at least one tip about brake jobs that includes removibg calipers :D
[Modified by Phil-tha-Rush, 10:53 AM 12/19/2002]
Old Dec 19, 2002 | 11:53 AM
aroulette's Avatar
aroulette
Default Re: painting Callipers (Phil-tha-Rush)
do you remove the pads and all before cleaning and painting?
Old Dec 19, 2002 | 12:53 PM
luvmy92's Avatar
luvmy92
Those 2 bolts should be torqued to 160 - 170 foot pounds I believe. They can be a real bear to get off. As for removing the pads, you better or they may not work any more. :D
What do you plan on painting them with?
Mike
Old Dec 19, 2002 | 02:20 PM
aroulette's Avatar
aroulette
Default Re: painting Callipers (luvmy92)
paint! LOL. Engine paint. Any other suggestions?
To painting Callipers
