Knock sensor, How many?
Old Dec 19, 2002 | 10:43 AM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
Default Knock sensor, How many?
I have a 96 LT1. I have been told I have 1 knock sensor and I have been told I have 2. Does anyone know for sure how many a 96 LT1 had? I am not talking about the knock module that goes into the computer. Thanks in advance.
Old Dec 19, 2002 | 04:10 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Knock sensor, How many? (UB2 SLOW)
Anyone? All I hear is the crickets! Anyone?
Old Dec 19, 2002 | 04:25 PM
NightRyder's Avatar
NightRyder
i donno... but couldnt you just look? i know i only got one. and i broke it :eek:
Old Dec 19, 2002 | 05:02 PM
STL94LT1's Avatar
STL94LT1
You have two knock sensors, one on each side of the block.
Dan Parker '96's Avatar
Dan Parker '96
I pulled one from each side of the block to drain it before removal. So I'd say you've got two.
Old Dec 19, 2002 | 05:28 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Knock sensor, How many? (Dan Parker '96)
Thanks, I have no idea where they are, so I could not look. I plan on finding out and changing them this weekend.
Old Dec 19, 2002 | 06:10 PM
NightRyder's Avatar
NightRyder
hey.. does my car have two, too? ... if so, thats not good. cuz i only have one on drivers side.
Old Dec 21, 2002 | 02:13 PM
Juliet's Avatar
Juliet
Default Re: Knock sensor, How many? (NightRyder)
My '87 has one knock sensor and 2 Oxygen sensors. ~Juliet
Old Dec 22, 2002 | 10:35 AM
PTz-92-LT1's Avatar
PTz-92-LT1
LT-1 = 2
Old Dec 22, 2002 | 11:43 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Default Re: Knock sensor, How many? (Juliet)
Should only have one of each???
Old Dec 22, 2002 | 12:24 PM
FELNGR8's Avatar
FELNGR8
Why exactly are you going to change them out? If you don't know where they are how can you have done the diagnostics to determine you have a failure?
I have been doing some reading in the service manual about them. If you have a DVM then determining if they are good or bad is relatively simple. Check page 6E3-C5-5.. If you don't have the service manual, why are you doing this? Do you have an internal noise that causes a problem with drivability?
Not that I'm any expert but that's a lot of work for nothing.
Old Dec 22, 2002 | 12:34 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Re: Knock sensor, How many? (94lt1torchred)
How do you get those things out anyway?
The old broken knock sensor in my '86 is in there tight as hell!
To Knock sensor, How many?
