HELP, FUEL PUMP JUST LET GO????
Old Dec 19, 2002 | 12:15 PM
C4Dreams's Avatar
C4Dreams
Default HELP, FUEL PUMP JUST LET GO????
Ok driving down my road, turn left onto the major road, got about 100 feet from my road when It dies, not electroicly but like no fuel type or no spark type...My Guess was bad fuel pump...I have NO idea....any one got ideas, it still cranks but no start and no studder no nothing...Spark or fuel ?
C4Dreams *about to give up* this thing is a POS, Every other week im fixin my car when the mustang boys laugh at me
Old Dec 19, 2002 | 12:25 PM
ittlfly's Avatar
ittlfly
Default Re: HELP, FUEL PUMP JUST LET GO???? (C4Dreams)
Pull off a spark plug wire, stick a screw driver into the plug wire where it was attached to the plug. Hold it next to the block while someone cranks it over and see if there is a spark jumping. No spark then it is ignition related . Spark, then probably fuel problem and a fuel pressure guage will help ID the bad component. ie: pump, FPR etc. Any codes?
Old Dec 19, 2002 | 12:31 PM
C4Dreams's Avatar
C4Dreams
Default Re: HELP, FUEL PUMP JUST LET GO???? (ittlfly)
No Check engine light if thats what u mean...
C4Dreams
Not all of us have these nice tools to diagnose. Fuel Pressure guage, Valve spring clearance tool, etc...I have no special tools. Wich is why i get screwed when something breaks
Old Dec 19, 2002 | 12:53 PM
Corvette0096's Avatar
Corvette0096
No you hear the fuel pump prime the system when the key is in the "ON" postion?
Old Dec 19, 2002 | 12:55 PM
C4Dreams's Avatar
C4Dreams
Default Re: HELP, FUEL PUMP JUST LET GO???? (corvette0096)
Never really have because of the fan on the car, and amps that make noises when u turn the car on.....
C4Dreams
Btw would a Buick Grand National Fuel Pump from 87 work in the vette? I have one of those from my GN sittin around...Might get me till i can afford to get a new one...
Old Dec 19, 2002 | 01:11 PM
Corvette0096
Your jumping the gun. I could be the fuel pump relay. You really need to find some one with a fuel pressure gauge.
Old Dec 19, 2002 | 01:56 PM
C4Dreams's Avatar
C4Dreams
No one around here has one, the people that do *machincs* want 50 to look at it...AHH i hate GA...no one wants to help a guy out these days...With my luck it will be the fuel pump...As for the relay is there a possible way i can test it without gettin a Guage? Its an OEM pump at 140k so im guessin its prob that...Ive never had a relay go...But if anyone knokws of somethig please let me know id like to be :steering: to work tommorw other than walking a 20 mile hike to work...Thanks
C4Dreams
prices on Fuel pumps???? I heard they were cheap anyone know of it...OEM dont need anythning else at this time....
Old Dec 19, 2002 | 02:05 PM
C4Dreams's Avatar
C4Dreams
OK here is the deal, i pulled off the Fuel OUT line the line that comes OUT of the fuel pump...Kicked it over a couple times...nothing no fuel no nada.....Does this help? I have a manual...so i knew which hose to pull off...Please i need to get this fixed today...thanks
C4Dreams
Old Dec 19, 2002 | 02:11 PM
Corvette0096
Change the fuel pump and relay at the same time, The relay is by the battery. As far as the one out of the GN, You will have to ask the dealer on that one. :cheers:
Old Dec 19, 2002 | 02:55 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
First you need to determine what is broken.
Check spark. Use an old spark plug, any spark plug. Ground the threaded area and hook it up and crank the car and see if you have spark.
If you have spark, check fuel. Have somebody turn the ignition to run (don't start) and listen to the fuel pump - should come on for 2 seconds or so. Does it? Go to engine bring a rag. Wrap rag around schrader valve on the drivers side runner, depress button in middle. Does fuel come out?
Old Dec 19, 2002 | 03:00 PM
C4Dreams's Avatar
C4Dreams
Default Re: HELP, FUEL PUMP JUST LET GO???? (PeteL)
i didnt do the srader valve or whatnot, but i did pull the pump out,,,,its dead...Now i dont know how to pull the damn old one out without ripping the Fuel Sock...Grrr ill just end up buyin a new one...prob i hope not..
C4Dreams
Old Dec 19, 2002 | 03:10 PM
PeteL's Avatar
PeteL
Hope it works out for you, good luck!
Old Dec 19, 2002 | 03:31 PM
VetBoy89's Avatar
VetBoy89
How did you determine that it was dead? Did you check the FP fuse? Just curious.
I've heard that you should buy a new sock whenever you replace the pump. I got mine at Kragen's for $6, they even had it in stock (I was shocked).
Good Luck. :cheers:
[Modified by VetBoy89, 12:32 PM 12/19/2002]
C4Dreams's Avatar
C4Dreams
Just for Future refrence...Buick Grand National Fuel Pumps are EXACTLY the same size, shape, connectors, etc.....tis a shame i left my VERY expensive Fuel pump in the buick lol...O well the one for the Corvette is 50 dollers plus 6 for the little fuel sock...Not to bad..2 bad its comin out of my damn paycheck says dad lol..O well...Guess thats why it was starting so bad huh...took forever to start rrrrrrrrr rrrrrrrrr rrrrrrrrrr rrrrrrbbbrrruummm... ya prob why huh...Guess i should have looked for the signs earlier on
C4Dreams
Pics will be posted tonight
Old Dec 19, 2002 | 03:33 PM
C4Dreams's Avatar
C4Dreams
Default Re: HELP, FUEL PUMP JUST LET GO???? (VetBoy89)
The pump i found out was bad becuase i have a little home made tester after i went through this with the buick...And nothing..nada nata thing...So i plugged in my old buick one,, bing we have liftoff...Now to go buy the new pump, install it and hope to god that the Relay is good.
C4Dreams
Old Dec 19, 2002 | 04:33 PM
C4Dreams's Avatar
C4Dreams
Ok so i hear nothing through the pump, pump is def dead...Put the new one in...I hear this one kick on....and prime...Just NOthing still..Nada....Fuel Pump relay?
C4Dreams
Old Dec 19, 2002 | 04:45 PM
scorp508's Avatar
scorp508
Yes, the GN pump from '87 will work. You might have to snip your wires and make new connectors, but the pump will work and I think that one supports up to something around 450hp.
p.s.
In the early C4s the fuel pump will prime the system for about 4 seconds when you turn the key on. If you turn the key off you have to count to 10 and turn the key on again before it will prime a second time. If you turn it on during those 10 seconds it will not reprime the system.
[Modified by scorp508, 4:47 PM 12/19/2002]
To HELP, FUEL PUMP JUST LET GO????
Old Dec 19, 2002 | 04:52 PM
C4Dreams's Avatar
C4Dreams
Default Re: (scorp508)
Ok does anyone know what might be wrong here???
Old Dec 19, 2002 | 04:55 PM
scorp508's Avatar
scorp508
It sounds like you aren't getting power to the pump or hte pump is dead for one reason or another. Before you go clipping things and throwing new parts out, find out why.
Disconnect the harness from the pump. Put a multimeter (+) lead on the switched 12v line and ground on the (-) one. A test light will also work. Have somebody turn the key on and watch the test light light up or monitor what voltage you get on the multimeter. As long as you get close to the same voltage you see on your dash your relay is most likely fine.
Old Dec 19, 2002 | 05:00 PM
VetBoy89's Avatar
VetBoy89
Default Re: (C4Dreams)
Did you check your fuel filter?
Have you checked your local parts stores (Autozone, Kragens, etc.) and see if they have a Fuel Pressure Guage you can borrow? Any local mechanic shops that will loan you one for a deposit? It will make things a lot easier if you can get your hands on one.
