I’ve got a stock 1986 corvette and I’m replacing the spark plugs and wires. Would there be any benefit to purchasing more expensive plugs and wires or are most of the more expensive parts priced that way to rip us off 😅
If your car is stock I don't see much benefit to the non-OEM wires. I went AC Delco RapidFire plugs but the standard AC plug for the 86 Corvette is probably fine. If you have the aluminum head '86 vs the cast iron head '86 it makes a difference in which plug you get, but I don't see a major difference in the results unless you've got some modifications to the motor which would benefit from a hotter / colder plug.
The problem with the Rapid Fire plugs is they aren't gapped to the correct spec and supposedly you aren't supposed to adjust the gap. I went with NGK platinum plugs just because the tip is smaller and supposed to burn a little hotter and thus is supposedly not going to foul out as quickly as regular copper plugs.
You won't get any benefit, its mostly what you want to spend.
I splurge on MSD 8.5mm wires, but run cheap Autolite plugs in my 398. You don't get anything by running super-expensive plugs or any other HEI components unless you're pulling a lot of RPM where it falls off. In an 86, you arent.
Yes, you're right, and I did some checking on this as the factory spec for our plug gaps ('89) is .035. The Rapid Fire 5 plugs recommended for my engine come with .047-ish gap from the factory. The AC Delco fitment guide for the '89 Vette with Rapid Fire advises the gap at .045. So that's what I set them to, figuring that bending the contact that small amount isn't going to hurt their durability.
I used a set of the Rapid Fire Plugs from AC Delco and they worked great in my C4. They worked well for me for a couple years. I also tried them in my C3 with its high energy ignition system that burns away electrodes on some plugs. The Rapid fire plugs are not to radical and were reliable for me in both Corvettes. They are a very stable and made great strong sparks. I strongly recommend them to fellow Corvette owners.
I tried the NGK Iridium plugs and they became fouled within a month of use. Don't waster your money on them. They fouled so badly in my 12.25-1 Compression 427 that I will never try then again.
I agree with vader86 on this point. I use the MSD 8.5 mm "Super Conductor" wires as well but have stopped wasting money on expensive Spark Plugs. Getting the spark to the plug is more important.
