throttle positioning sensor
Old Dec 19, 2002 | 04:09 PM
atotalnincompoop's Avatar
atotalnincompoop
Default throttle positioning sensor
on a stock engine ('85) the TP sensor is suposed to be set at .54 Volts.
do i adjust it back to the stock setting on a modified engine, or does anyone out there know what it should be set too. check my sig for my mods if that will help, i just relpaced my modified throttle body with a stock one as an experiment, so i need to reset it. :cheers:
Old Dec 19, 2002 | 04:58 PM
scorp508's Avatar
scorp508
Yep... 0.54v at idle is stock location. You can actually run it as high as 0.68v before throwing a computer code. You also want to make sure that when the accelerator is depressed fully that you get close to 4.50v
Old Dec 19, 2002 | 10:19 PM
atotalnincompoop
Default Re: (scorp508)
thanks scorp :cheers:
Old Dec 20, 2002 | 10:44 AM
montecarlo4's Avatar
montecarlo4
Default Re: (atotalnincompoop)
How much on a 84, and where do you check the volts at?
I was just going to check mine and see if its set right.
thanks
matt
Old Dec 20, 2002 | 03:24 PM
Blue88's Avatar
Blue88
Default Re: (montecarlo4)
http://www.geocities.com/jgkov/TPSService.html
Old Dec 20, 2002 | 07:26 PM
atotalnincompoop
an '84 is different than an '85, so the procedure is different as well, it should say in you service manual :cheers:
To throttle positioning sensor
