long tube headers???
Old Dec 19, 2002 | 11:13 PM
DRAGRCR1005's Avatar
DRAGRCR1005
Default long tube headers???
I HAVE A 92 VETTE WITH THE LT1. ANYONE EVER DONE LONG TUBES AND IF SO WHAT KIND AND HOW IS THE FIT? HOOKER LISTS A NUMBER BUT IT IS THE SAME AS THE SHORTY HEADERS??
Old Dec 19, 2002 | 11:22 PM
vader86's Avatar
vader86
Default Re: long tube headers??? (DRAGRCR1005)
The only real advantage of shorty's is weight savings over the stock manifolds, theres only a small power gain.
Hooker 2149 or 2151 is the longtubes everyone uses, however getting cats to fit with longtubes can be a problem. You should gain around 10-15hp from longtubes.
Old Dec 20, 2002 | 12:00 AM
GRX's Avatar
GRX
Default Re: long tube headers??? (vader86)
Vader86, what diameter are those tubes?
Old Dec 20, 2002 | 12:53 AM
vader86's Avatar
vader86
Default Re: long tube headers??? (GRX)
You can get them in 1 5/8" or 1 3/4" if i remember correctly (i'm on dialup, so i cant really check myself on that)
Old Dec 20, 2002 | 09:16 AM
luvmy92's Avatar
luvmy92
I have the coated TPIS long tubes and like them a lot. They are 1.75" and have 3" collectors. Since I'm in Florida, I do not have cats but you could bolt some high-flow Bullit cats up to them. I have a 3" Tri-Flow bolted up to them (had to cut a little off on one side and also need to use a couple of 8" long test pipes in between the headers and exhaust). I also replaced the resonator with a 3" X-Pipe. This combination will cause your neighbors to call the cops every time you fire it up. :D
Here's a pic of them...
Mike
[Modified by luvmy92, 8:19 AM 12/20/2002]
To long tube headers???
