[HELP] brake upgrade problems
Old Dec 19, 2002 | 11:51 PM
enhance's Avatar
enhance
Default [HELP] brake upgrade problems
I GOT to get this done.
I got the fronts pretty much done now, excpet for the stupid bolt that broke.
I'm doing the backs now, I had to take the wheel wells off to get room for my torque wrench.
Question:
I am putting the pads in, but there isn't room now for the rotors to fit in.
I think I have the piston depressed as much as it can, but there still isn;t enough room.
Any suggestions??
Old Dec 19, 2002 | 11:55 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: [HELP] brake upgrade problems (enhance)
Did these come as a set? Are the pistons fully recessed before you tried to put the pads in? I am sure they are and that is probably a stupid question I am just trying to picture where you are at in the install.
Old Dec 20, 2002 | 12:53 AM
enhance's Avatar
enhance
Default Re: [HELP] brake upgrade problems (CowboyNVette)
I got some bigger pliers and got them compressed more and one, thanks :cheers:
Old Dec 20, 2002 | 10:01 AM
ittlfly's Avatar
ittlfly
For future reference, just crack the bleeder a little and the piston(s) will push back into the bores a lot easier. That takes the fluid pressure off them. :thumbs:
To [HELP] brake upgrade problems
