Code 32 mystery
Old Aug 25, 2021 | 06:48 PM
DWAVette's Avatar
DWAVette
Default Code 32 mystery
1991 Coupe, stock L98.
Recently pulled intake. New gaskets, vacuum lines, all new EGR components.
Car has been running great with no codes for several months.
Recently began getting a Code 32 SES but only when I go over 65 or so mph.
I can drive for 30 miles under 64-66 mph and no code.
If I hit the Interstate, it gives a Code 32 within a few minutes.
Any suggestions or ideas?
Old Aug 25, 2021 | 07:22 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Code 32
Code 32 is EGR.
check your vacuum lines to solenoid and make sure temp sensor wire did not fall off.
that wire gets brittle over time and breaks.
on my 86, the wire just broke.
the sensor resistance changes when hot exhaust is flowing in the tube which is the signal the computer reads that verifies the egr is called for, the vacuum lines are intact, and the valve is working
Old Aug 25, 2021 | 07:57 PM
DWAVette's Avatar
DWAVette
Originally Posted by coupeguy2001
Code 32 is EGR.
check tour vacuum lines to solenoid and make dure temp sensor wire did not fall off.
the sensor resistance changes when hot exhaust is flowing in the tube which is the signal the computer reads that verifies the egr is called for, the vacuum lines see intact, and the valve is working
Thanks for the response. On the ‘91, there is no temp sensor in the EGR tube from exhaust manifold to intake manifold.
I recently replaced the plug on my EGR solenoid, however, I will double check my soldered wire connections.
Old Aug 25, 2021 | 08:58 PM
coupeguy2001
Default Egr
The sensor on an 85 is on the valve.
maybe they went back to that configuration
when you say you soldered the wires, are they in an sreathat would melt the solder?
if so, crimp or silver solder is the fix
Old Aug 26, 2021 | 04:05 AM
DWAVette's Avatar
DWAVette
Originally Posted by ihatebarkingdogs
There is no EGR diagnostic temp sensor on the 90-91. The 90-91 DTC32 is a completely different strategy than the temp sensor used in 85-89. The diagnostic requires no closed-throttle for about 3-4 minutes, and this condition is generally only met at highway speed. If the throttle is completely closed, the timer starts over.
Restricted EGR passages in the manifold, pipes or plenum can cause Code 32.
Ok, now I see why it only sets after the interstate. The system has been doing fine for months, so I may have something causing a restriction in exhaust flow. I will pull my EGR tube and EGR valve and make sure all the passages are open.
I should be able to blow compressed air from the inlet port on the intake through to the EGR valve port, correct?
To Code 32 mystery
