1990 no start
Old Sep 1, 2021 | 05:04 PM
Split29's Avatar
Split29
Cruising
Default 1990 no start
Hey guys I have a 1990 that has a after market alarm system on it and will not start. Wondering if you guys can lead me to any good wire diagrams for dummies lol. Or have any ideas.
Old Sep 1, 2021 | 11:28 PM
jv9999's Avatar
jv9999
Start with the basics. Does it have spark? Fuel pressure? Injectors pulsing? Not much else we can tell you without specifics on the alarm. You might want to invest in a factory service manual.
Old Sep 2, 2021 | 12:22 PM
Split29's Avatar
Split29
Cruising
Duh lol. Every thing turns on when I turn the key to the on position. But I get no crank and a brake indicator light comes on when I try to turn it over. I have fuel at the rail how do I check if the injectors are firing?
Old Sep 3, 2021 | 10:17 PM
aklim's Avatar
aklim
Hook up an idiot light to the exciter wire (not the positive cable) and try to crank. Is it getting 12V?
Old Sep 5, 2021 | 11:35 AM
ctmccloskey's Avatar
ctmccloskey
Measure the Battery voltage and then measure it again at the fuse panel using the chassis for ground. They should be the same or close.
You might need a set of the Factory Service Manuals for your 1990. They are available for ~$85 in hard copy, RockAuto sells them much cheaper on a DVD. They have all the schematics and troubleshooting guides you could ever want in them and it is accurate to boot!
Your injectors all have 12 volts DC going to them when the Corvette is in the "Run" Position. The ECM will send a ground to make them inject the fuel. Be careful checking the wires around the injectors as their insulation might start coming off. I have seen several C4's with crumbling insulation on the injector wires that sit on top of the engine. You do not want to use any self powered testing device that might hurt the ECM.
Your Fuel system is in fact "priming" the engine to run but no cranking or starting?
Old Sep 8, 2021 | 05:31 PM
Split29's Avatar
Split29
Cruising
I'm pretty sure I have narrowed it down to the vats system. I bypassed the starter relay got it to crank but still no start. She has spark. Is there a way to bypass the fuel part of vats?
To 1990 no start
