Ok, so a friend of mine was trying to help me out when he "found" a Dana 60 full floater with 4:10 gears and a power lock 19 spline axles, drum brakes outta a 72 f 250 4x4. dropping everything but the differential (and the fact that it's 30 years old), would it even FIT under the car? I've never laid eyes on one so I'd like to know what the spline # is for an 84 if anyone recalls, and how futile it would be for someone to even think about putting one of these back there....
My guess is that you are thinking that there are more similarities between the Ford truck Dana axle and our C4 Dana axles. The truck 60 is a solid axle assy. There is no "dropping everything else". The axle tubes are pressed and welded into the center section. Our 36 or 44 ICA (ICA = independent carrier assy.) axles are a Dana carrier assembly designed for indepentant mounting from the rest of the axle assy. With a lot of ingenuity and labor, a skilled machinist may be able to convert the center carrier portion of that axle into an independent carrier, but it would be a MAJOR undertaking. I have heard stories of it having been done, but I've never seen one. The other alternative, involving the use of that axle would be to convert your car to a solid axle car. The modifications to the axle assy would be extensive in this case, too, but not "ground breaking". Pictures may show up in response to your post, of converted differential assys.
If you want to use it as a solid axle then that should be doable but they are VERY HEAVY
Doable, yes, but still not inexpensive. The axle assy is going to have to be narrowed. The full float hubs and axle spindles are going to have be done away with, and that ancient 19 spline diff needs up dating. Mark Williams and others specialize in making axle assys to fit race cars and other applications. The cost of the "find" will quickly dissappear in the cost of the conversion.
