C4 stiff steering
Old Sep 18, 2021 | 07:33 PM
MikieGS60th's Avatar
MikieGS60th
6th Gear
Default C4 stiff steering
C4 steering is very stiff. Lots of air in tires, alignment appears correct. Any ideas?
Old Sep 18, 2021 | 08:55 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i “flushed” my 87, 86 and 85 steering racks with acetone and atf mixture. I let it sit in the rack for 5 min. then flushed with 100% atf and called it hood. i use atf as power steering fluid.
the “flush” procedure can be exciting. i fill the reservoir, and disconnect the return line and direct it INSIDE a 2 litre pop bottle. i tape the hose in the bottle!! the fluid flow and pressure out of the power steering pump is much much higher than i expected.
it will drain the reservoir in a second or two. so i was starting the car and shutting it down immediately to displace all the fluid. i raise the front wheels during this procedure so that i can turn the wheel left and right several times to move fluid in the rack.
the “soak” with acetone atf mixture was an experiment that worked, i had a rack that was VERY STIFF on center and turning the wheel required tonnes of force and then it would let go and jerk the car. im not sure why it worked or what the atf/acetone did, it was a shaken mix (put 50/50 into 2litre pop bottle and shook it up). that rack was fixed afterwards and i tracked the car several times afterwards prior to selling it. your results may very. use plain atf if you want to simple displace dirty fluids. you need to turn rack from lock to lock to be thorough. good luck.
Old Sep 18, 2021 | 11:24 PM
MikieGS60th
6th Gear
Great idea. I'll try it! Thanks!
Old Sep 19, 2021 | 11:49 AM
ex-x-fire's Avatar
ex-x-fire
My way of flushing them is to blow compressed air both ways, my reasoning is how are you going to unstick something when it only flows in one direction. It works too.
To C4 stiff steering
