Intermittent Stumbling on Acceleration
Old Dec 21, 2002 | 02:23 PM
Live95's Avatar
Live95
2nd Gear
Default Intermittent Stumbling on Acceleration
I drove through a puddle during the rain storms here in California and the car began to stumble like a wet ignition. Park it for few days to dry out the ignition. Now it acts as if it has wet ignition only sometimes and at idle or low rpm. Fuel system or Opti-Spark problems? :cry
Old Dec 21, 2002 | 07:15 PM
don hall's Avatar
don hall
Default Re: Intermittent Stumbling on Acceleration (Live95)
Live95, I don't have an answer for you, but I don't want your first post to go unanswered. Access any trouble codes that may exist. Water is an opti killer, so it is possible that you are experiencing the beginning of opti failure. Hesitation on acceleration was a symptom I experienced before my opti failed. Let's hope it is something else, but check your trouble codes first.
Old Dec 21, 2002 | 07:43 PM
Live95's Avatar
Live95
2nd Gear
Default Re: Intermittent Stumbling on Acceleration (Oldman)
Thanks Old Man. I'll figure how to pull the codes and pray. :cheers:
Old Dec 21, 2002 | 07:51 PM
don hall's Avatar
don hall
Here is a link to some good Corvette "stuff", including codes, etc. in case you are not familiar with this site: http://www.c4vettes.com/indepth_launch.htm
To Intermittent Stumbling on Acceleration
