Strange Headlight Problem
Old Sep 24, 2021 | 09:40 AM
SuicuneFox's Avatar
SuicuneFox
Default Strange Headlight Problem
On my '87, the passenger headlight randomly stopped going back down. I kept hearing a ticking sound every now and then coming from the motor even after I turned the switch off. I disconnected the battery and manually put it back down. I tried to open the headlights again, and it opened fine, but when I closed them, it went about halfway down then got stuck and the ticking noise resumed. I tried to turn the **** while it was on, and when the ticking noise happened, the motor turned the headlight back up to where it got stuck, not down. I manually put it back down again, connected the battery, and when I closed the hood, the passenger headlight randomly opened back up again. Couldn't find anyone with this specific problem and I'm new to working on cars. Any suggestions?
Old Sep 24, 2021 | 10:17 AM
IndyC4Vert's Avatar
IndyC4Vert
That’s a very typical thing with the C4 vettes. There are plastic gears in the headlight motors that after a long time the gears get worn down and they’ll grind like that. They make new nylon gears and bronze gears for replacement. I replaced mine with nylon. Figured it work for over 20 years I’d keep the nylon ones. Around $25-30 for both and maybe an hour and a half or 2 if you’re a “challenged” mechanic like me. I’m semi-handy. Someone good with their hands? Under an hour. I did the nylon because I hear that the bronze gears were harder in the headlight motors and could burn out a motor. Those are around $250.
You can find a video on how to swap those gears out on YouTube really easy. That’s how I did it.
Old Sep 24, 2021 | 10:20 AM
SuicuneFox's Avatar
SuicuneFox
Thanks! I'll try that. Wasn't sure if it was the gears or something else.
Old Sep 24, 2021 | 11:53 AM
s carter's Avatar
s carter
odds are its just the bushings which are cheap $10. +- for both sides, but if you have it apart I recommen having gears in hand though it does jack the cost a bit unless you're like me and live with a corvette only parts store down the street
If you want the gears they are $25.00 for each side, bushings are $6.00 each side
Old Sep 24, 2021 | 12:02 PM
SuicuneFox's Avatar
SuicuneFox
Thanks I'll get some too! Sadly, I do not
Old Sep 24, 2021 | 12:46 PM
SuicuneFox's Avatar
SuicuneFox
Do you know where I can find the bushings? I'm not seeing any on Ecklers or anywhere else
Old Sep 24, 2021 | 01:15 PM
KMS88Cal#16's Avatar
KMS88Cal#16
Corvette Central has the bushings for $5.95 and the nylon gears kits for $24.95.
Old Sep 24, 2021 | 01:16 PM
SuicuneFox's Avatar
SuicuneFox
Thank you
Old Sep 24, 2021 | 01:43 PM
SuicuneFox's Avatar
SuicuneFox
Do you have a link to the bushings? I can't seem to find them for some reason.
Old Sep 24, 2021 | 01:48 PM
s carter's Avatar
s carter
parts store down the block
https://corvetteparts.com/item/dowel...ings-1988-1996
https://corvetteparts.com/item/gear-headlamp-motor-1988-1996
Old Sep 24, 2021 | 02:23 PM
SuicuneFox's Avatar
SuicuneFox
Oh I have an 87. Does 87 not use the bushings? I haven't had a chance to open the motor yet.
Old Sep 24, 2021 | 02:32 PM
KMS88Cal#16
Default Gears
Looks like 87’s just have gears. I don’t know how to post a direct link to them. I just used corvettecentral.com and then searched for “headlight gears” and found them. One big gear and 1 small one. Kevin
Old Sep 24, 2021 | 03:08 PM
SuicuneFox's Avatar
SuicuneFox
Oh ok. I found them. Thanks!
To Strange Headlight Problem
