understand code 43
Old Sep 26, 2021 | 06:43 PM
ps374's Avatar
ps374
Default understand code 43
I have a code 43 and 44 on my 1984.I am having some trouble understanding the FSM. On page 6E2-46 it says if you have over 6 volts in your ECS sensor (electric spark control ) from pin 486 the black wire. Mine reads almost 10 volts. I believe I checked it from terminal C the black wire. Then on page 6E2-47 it says if it reads over 10 volts the ESC is bad? Does this mean the module is good or bad? I assume the 44 is because of the 43? What am I missing here.
