Won't Start
Old Sep 27, 2021 | 01:50 PM
MarkB85vette's Avatar
MarkB85vette
Default Won't Start
Hello all,
My 85 C4 had the starter spin out of control and smoke so I installed a new OE AC Delco starter. The ring gear on the flex plate looks pretty good over all. Just a very small flat spot, not worried. The issue is after I installed the new starter, it won't start, at all. Nothing. I have power to everything. I pulled the starter relay and ordered a new one. Should have it tomorrow. Any advice would be great if after I put in the new relay and still get nothing. Thanks in advance for the support
Mark
Old Sep 27, 2021 | 07:12 PM
Jowens7896's Avatar
Jowens7896
Theres a fusable link in the power wire to the starter did you check it
Old Sep 27, 2021 | 09:54 PM
MarkB85vette
I am a dumb ***. After some very careful observation I noticed I had it wired to the R terminal and not the S terminal on the cellinoid. Swapped it, fired right up. Took my dash apart for no reason. Anyway thanks for the response.
Mark
Old Sep 27, 2021 | 10:16 PM
Jowens7896's Avatar
Jowens7896
Glad you got it running wish I could get mine figured out
Old Sep 28, 2021 | 05:27 AM
MarkB85vette
What is the issue with your vette?
Old Sep 28, 2021 | 05:49 AM
Jowens7896's Avatar
Jowens7896
Turns over wont start it has spark and fuel pressure but no injector pulse. Has engine code 46 which is VATS Fault but i used a resistor and bypassed the system. It will run if i continue to spray carb cleaner or starting fluid in plenum.
Old Sep 28, 2021 | 06:32 AM
MarkB85vette
I had similar issues with my C4. What fixed it for me was taking apart the intake, TB, Plenum, etc, and put it back together with new injectors, sensors, gaskets. Has run great ever since. Conventional wisdom says to not throw parts at it, but in my case it worked after months of chasing codes. New O rings too.
Old Sep 28, 2021 | 09:05 AM
ctmccloskey's Avatar
ctmccloskey
Hello Jowens7896
I was under the impression that the Distributor has something to do with generating the signals for the injector pulse. Have you done anything to the distributor in all your work?
When you measure the battery voltage at the battery and then measure the battery voltage at the Fuse panel, are they the same numbers? Sometimes a voltage drop can cause issues.
Old Sep 28, 2021 | 09:18 AM
Jowens7896's Avatar
Jowens7896
No voltage drop. Injector ohms are in spec. Have spark put in New Ignition control module.
To Won't Start
